About tvarset.src
ivory4
About tvarset.src
Unread post by ivory4 »
There are two procedures, tvarying as an exercise, tvarset.src as a procedure for general var.
How to record history of time varying coefficients?
I tried "cohistory" option, it is said to be available only for one equation model.
Question2:
How to use tvarset.src?
Just by
@ tvarset(options)
# list ??
Also how to record the history of time varying coefficients?
* TVARYING.PRG
* Example from User's Guide section 10.13.2,10.13.3
* Typo in decayfac (wrong sign) corrected 10/2007. Thanks to
* Rodolfo Mendez for pointing this out.
cal(q) 1959
open data haversample.rat
data(format=rats) 1959:1 2006:4 gdph fm1
log gdph
log fm1
compute kstart=1960:1,kend=2006:4
equation kalmeq gdph
# constant gdph{1 to 4} fm1{1 to 4}
declare vector b(9) bmean(9)
ewise bmean(i)=(i==2)
associate(perm) kalmeq b
linreg gdph
compute gseesq=.9*%seesq
linreg fm1
# constant fm1{1 to 4}
compute mseesq=.9*%seesq
*  Set up the system. Use GSEESQ as the measurement equation variance
system kalmeq
kfset(constant,noscale,likelihood=likely) xxx
# gseesq
tvarying tvx
* The hyperparameters (PIx) below are the following:
*   PI5 = Overall tightness. This corresponds to TIGHTNESS**2 on
*         SPECIFY.
*   PI2 = Relative tightness on other variables. This corresponds
*         to w**2 on the symmetric prior.
*   PI3 = Relative tightness on the constant. (No correspondence).
*   PI7 = Relative tightness on time variation.
*   PI8 = Shrinkage factor toward mean (between 0 and 1 , 1 = no shrinkage)
*  This uses a HARMONIC decay with DECAY=.5
compute pi5 = .20**2
compute pi2 = .5**2
compute pi3 = 10000.
compute pi7 = 0.00000001
compute pi8 = 1.00
dim xxx(9,9) tvx(9,9)
compute likely=%const(0.0)
compute b=bmean
compute xxx=%const(0.0)
compute xxx(1,1)=pi5*pi3*gseesq
do i=1,4
  compute decayfac=i**(-2*.5)
  compute xxx(i+1,i+1)=pi5*decayfac
  compute xxx(i+5,i+5)=pi5*pi2*decayfac*gseesq/mseesq
compute tvx=pi7*xxx
do time=kstart,kend
  if time==kstart
     kalman(start=time)
  else {
     compute b=pi8*b+(1-pi8)*bmean
     compute xxx=(pi8**2)*xxx
     kalman(print=(time==kend))
end do time
