problem of procedure
Posted: Wed Oct 30, 2024 10:43 am
by hardmann
Dear Tom:
I want to estimate repeatedly the local trend and ar(2) model, trend/cycle decomposition. Thus, I try to write a procedure.
I use tow methods to config ar2. However, one is successful, another is failure.
Please help me.
Best regard
Hardmann
Re: problem of procedure
Posted: Wed Oct 30, 2024 12:58 pm
Shouldn't this be 1 0 1 0?
input c
1 1 0 0
Posted: Wed Oct 30, 2024 10:41 pm
by hardmann
Dear Tom:
In two procedeure, I use different order of states. These have led to errors. I have modified and unified these.
but LTandAR2decom.src till report an error as follows:
## CP24. PROCEDURE/FUNCTION LTANDAR2DECOM compiled with errors. Please correct
if using swf as local frml, error is
## SX22. Expected Type RECTANGULAR[SYMMETRIC[REAL]], Got MATRIX[REAL] Instead
>>>>zeta^2,sigeps^2||)<<<<
Best regard
Hardmann
Posted: Thu Oct 31, 2024 8:25 am
It's on the line before that. You have SW declared as:
local rect[symm] sw
which looks like it should be just
local symm sw
If you have a problem like that with a procedure, don't do a source instruction. Bring it in as an input file. That way you can do the Edit---Show Last Error to show you the exact line that had the syntax error.
Posted: Thu Oct 31, 2024 12:07 pm
by hardmann
Dear Tom:
I correct it. But problem still reserves.
I am still confused about "Bring it in as an input file."
It always report error. It seems to be related to " function DLMYSetup".
Best Regard
Hardmann
Posted: Thu Oct 31, 2024 3:21 pm
You're inserting this inside the procedure:
function DLMYSetup
compute a(3,3)=ph1,a(3,4)=ph2
compute sw = %diag(||sigxi^2,sigzeta^2,sigeps^2||)
You can't do that. You can't nest functions or procedures in-line; the inner one has to be defined first, which wouldn't work as you have done this since the function is using variables from inside the procedure. Your SWF FRML will take care of SW. You can easily redo the reset of A as a FRML[RECT] rather than a FUNCTION.
Open the file. Make it the input file. (Make a second text window as Output). Select All. Run. The errors will go to the Output window and you can use Edit---Show Last Error to show the location where you had the error.
Posted: Sun Nov 10, 2024 6:04 am
by hardmann
Dear Tom:
On page 58 of the second edition of the RATS Handbook for State-Space Models, the alternative method is gaven, which use the START option on DLM to “poke” the ' values into the proper slots in an otherwise fixed A matrix and then let that (now fixed) matrix
be used in evaluating the log likelihood. The method executes faster and will be useful in more complicated models. When I decomposed the GDP into the local trend ,ar(2) and seasonal components, I use the mothed instead of traditional method that somrtimes does not work.
I am confused why it cannot be used for procedure?
Bset regard
Hardmann
Posted: Sun Nov 10, 2024 10:46 am
by hardmann
Dear Tom:
The code is right.
There is an incorrect comment on LocalDLM.src as follows
* TYPE=TREND is the local trend model. The two states are the local
* level and the local rate of change.
* 1 1
* A =
* 1 0
it should be
* 1 1
* A =
* 0 1
Best regard
Hardmann
Posted: Sun Nov 10, 2024 3:38 pm
As I said, you can use FRML's to accomplish the same thing. You already have a FRML to take care of SW.
local frml[rect] afrml
instructions which set the fixed parts of a
frml afrml = a(3,3)=ph1,a(3,4)=ph2,a
dlm(a=afrml,...)
Posted: Sun Nov 10, 2024 6:22 pm
by hardmann
Dear Tom:
This method is work. I try altertive which is more effect in more complicated models. Sometimes, the FRML can not get right result.
Best regard
Hardmann
Posted: Sat Feb 15, 2025 11:39 pm
by hardmann
Dear Tom:
If someone want to perform trend and cycle decomposition of GDP for multiple countries, assuming the trend is a second-order unit root and the cycle is an AR(2) process, can it be written as an SRC file for repeated calls, similar to bndecomp.src? It could even include options for the trend, similar to localdlm.src. Additionally, for real-time analysis, it could also be used to repeatedly estimate real-time data.
I attempted to write it but was unsuccessful, so I am seeking your assistance. I believe it is highly necessary to be created.
Best Regard
Hardmann
