Structure Panel Data Set
Posted: Fri Aug 07, 2009 5:09 pm
I work with panel data for agricultural support.
OECD countries (12) for "i". In
1986-2008: for "T"
3 endogeneous: y1, y2, CPI:
2 exo: API, dummy.
Following Hsiao(1986) there are assumptions before using a panel data set (UG 548) with the model Yit= Ait + Bit+eit
1- For individual (i) all coefficients are assumed to be constants (pooled panel). i.e Ho: A,B=Ai,Bi
If Ho is not true, then there is heterogeneity. The next step is to test if this heterogeneity comes from the coefficients(Bit)..
2-Heterogeneity of estimators: Ho: Ai,B=Ai,Bi. If Ho is rejected, panel data must not be used because only intercept might be similiar for all countries. Country by country must be regress instead of using panel data.
3. If Ho cannot be rejected, the next step is to test if Ho: A,B=Ai,B for all countries. If it is rejected, I have to test if the individual fixed or random effects.
4. I have to use Hausman test to know if there is fixed of random individual effects.
Above, it is my way to resolve the tests. I hope I was clear.
My problem is: How can I do this with RATS?? I am completely confused with the options I have on the Panel Regression Wizard. I switch to RATS programming because, with Stata, I was not able to run a VAR Panel.
In the Panel Regression Wizard, I keep the Effects: Individual.
For #1: I don't know
For #2: I think I have to use the Method: Between
For #3 #4 I don't know
Do I have to use pregress of pstats?
Thank you very much if somebody can help me!!
Nadia
1986-2008: for "T"
2 exo: API, dummy.
Nadia
