Power transformations and ARIMA
Posted: Thu Jun 17, 2021 4:57 am
For ARIMA modelling,
If I am to model log-returns i.e 1st differences of a logged series, based on:
(i) A transformation 'typically' applied to the series in the academic literature, and
(ii) @BJTRANS, choice of transformation which produces approximate uniform variability i.e. the log transformation.
Then on BOXJENK I would input the depvar as 'log of the series' and use DIFFS=1.
After generating forecasts on the transformed data I would exp the forecasts, i.e. back to the original scale.
However, on any series:
(a) If @BJTRANS says e.g. the square-root of the series stabilises the variance the best, then
(b) use @BJDIFF for an automated choice for the DIFFS, SDIFFS and CONSTANT options, then
(c) on BOXJENK input the depvar as 'sqrt of the series' and the appropriate choices via @BJDIFF.
After generating forecasts on the transformed series I would square the forecasts, i.e. back to the original scale.
Questions:
(1) I want IID-Normal residuals, am I aiming for a transformation e.g. via @BJTRANS which produces a Normal distribution in the LEVELS series, or a Normal distribution for the DIFFS series (DIFFS>=1), or both?
(2) Also, is it more appropriate to stick with a transformation 'standard' in the academic literature for the series or that suggested from the empirical data?
(3) Both a log transformation and a square-root transformation are part of the family of Box-Cox/Yeo-Johnson power transformations, depending on lambda, used to stabilize variance and make the data more normal distribution-like https://en.wikipedia.org/wiki/Power_transform. How would I apply a Box-Cox/Yeo-Johnson transformation to choose an optimal value for lambda, and then back-transform the forecasts in RATS?
thanks,
Amarjit
Questions:
thanks,
Amarjit
