## SX20. Expected ) Here error
Posted: Tue Jun 01, 2021 5:09 pm
I am getting an "## SX20. Expected ) Here" error:
>>>>au_f(1)-tau_s(1)))<<<<
But as far as I can tell, all the parentheses all close each other. I know from previous advice that is better to write this as a function, but I would also like to correct the below if possible.
In addition, when I simply display the two terms, I don't get an error.
Adam
frml Cf = ||1.0,-((exp(-lambda*tau_s(1))-exp(-lambda*tau_f(1)))/(lambda*(tau_f(1)-tau_s(1)))),((tau_s(1)*exp(-lambda*tau_s(1))-tau_f(1)*exp(-lambda*tau_f(1)))/(tau_f(1)-tau_s(1)))+((exp(-lambda*tau_s(1))-exp(-lambda*tau_f(1)))/(lambda*(tau_f(1)-tau_s(1)))),0.0,0.0,0.0|$
1.0,-((exp(-lambda*tau_s(2))-exp(-lambda*tau_f(2)))/(lambda*(tau_f(2)-tau_s(2)))),((tau_s(2)*exp(-lambda*tau_s(2))-tau_f(2)*exp(-lambda*tau_f(2)))/(tau_f(2)-tau_s(2)))+((exp(-lambda*tau_s(2))-exp(-lambda*tau_f(2)))/(lambda*(tau_f(2)-tau_s(2)))),0.0,0.0,0.0|$
1.0,-((exp(-lambda*tau_s(3))-exp(-lambda*tau_f(3)))/(lambda*(tau_f(3)-tau_s(3)))),((tau_s(3)*exp(-lambda*tau_s(3))-tau_f(3)*exp(-lambda*tau_f(3)))/(tau_f(3)-tau_s(3)))+((exp(-lambda*tau_s(3))-exp(-lambda*tau_f(3)))/(lambda*(tau_f(3)-tau_s(3)))),0.0,0.0,0.0|$
1.0,-((exp(-lambda*tau_s(4))-exp(-lambda*tau_f(4)))/(lambda*(tau_f(4)-tau_s(4)))),((tau_s(4)*exp(-lambda*tau_s(4))-tau_f(4)*exp(-lambda*tau_f(4)))/(tau_f(4)-tau_s(4)))+((exp(-lambda*tau_s(4))-exp(-lambda*tau_f(4)))/(lambda*(tau_f(4)-tau_s(4)))),0.0,0.0,0.0|$
1.0,-((exp(-lambda*tau_s(5))-exp(-lambda*tau_f(5)))/(lambda*(tau_f(5)-tau_s(5)))),((tau_s(5)*exp(-lambda*tau_s(5))-tau_f(5)*exp(-lambda*tau_f(5)))/(tau_f(5)-tau_s(5)))+((exp(-lambda*tau_s(5))-exp(-lambda*tau_f(5)))/(lambda*(tau_f(5)-tau_s(5)))),0.0,0.0,0.0|$
1.0,-((exp(-lambda*tau_s(6))-exp(-lambda*tau_f(6)))/(lambda*(tau_f(6)-tau_s(6)))),((tau_s(6)*exp(-lambda*tau_s(6))-tau_f(6)*exp(-lambda*tau_f(6)))/(tau_f(6)-tau_s(6)))+((exp(-lambda*tau_s(6))-exp(-lambda*tau_f(6)))/(lambda*(tau_f(6)-tau_s(6)))),0.0,0.0,0.0|$
1.0,-((exp(-lambda*tau_s(7))-exp(-lambda*tau_f(7)))/(lambda*(tau_f(7)-tau_s(7)))),((tau_s(7)*exp(-lambda*tau_s(7))-tau_f(7)*exp(-lambda*tau_f(7)))/(tau_f(7)-tau_s(7)))+((exp(-lambda*tau_s(7))-exp(-lambda*tau_f(7)))/(lambda*(tau_f(7)-tau_s(7)))),0.0,0.0,0.0||
dis -((exp(-lambda*tau_s(1))-exp(-lambda*tau_f(1)))/(lambda*(tau_f(1)-tau_s(1))))
dis ((tau_s(1)*exp(-lambda*tau_s(1))-tau_f(1)*exp(-lambda*tau_f(1)))/(tau_f(1)-tau_s(1)))+((exp(-lambda*tau_s(1))-exp(-lambda*tau_f(1)))/(lambda*(tau_f(1)-tau_s(1))))
Adam
