Forecasting with ANN
Posted: Fri Mar 05, 2021 6:49 am
I am forecasting 12 steps ahead with an AR model with rolling window using the following code:
"clear rhatar rhatar2 rhatar3 rhatar4 rhatar5 rhatar6 rhatar7 rhatar8 rhatar9 rhatar10 rhatar11 rhatar12
do regend=2018:2,2019:2
boxjenk(ar=||1,2||,define=ar2) Dsalsn regend-60 regend
uforecast(static,equation=ar2) rhatar regend+1 regend+1
uforecast(static,equation=ar2) rhatar1 regend+2 regend+12
compute rhatar2(regend+2)=rhatar1(regend+2)
compute rhatar3(regend+3)=rhatar1(regend+3)
compute rhatar4(regend+4)=rhatar1(regend+4)
compute rhatar5(regend+5)=rhatar1(regend+5)
compute rhatar6(regend+6)=rhatar1(regend+6)
compute rhatar7(regend+7)=rhatar1(regend+7)
compute rhatar8(regend+8)=rhatar1(regend+8)
compute rhatar9(regend+9)=rhatar1(regend+9)
compute rhatar10(regend+10)=rhatar1(regend+10)
compute rhatar11(regend+11)=rhatar1(regend+11)
compute rhatar12(regend+12)=rhatar1(regend+12)
end do"
It works perfectly fine. I want to know if there is a way to write it in a parsimonious way?
Second, what would be a way to write such code for a neural network with 2 lags of the same variable itself. I am asking this because I am unable to define model as above (with the AR) for the neural network so that I can use the uforecast function.
Thank you in advance
Dr. Ateeb Syed
end do"
Dr. Ateeb Syed
