Identification of VIRFs
Posted: Tue Jan 05, 2021 3:14 pm
I have a question related to the identification of the shocks within an VIRF analysis as in Hafner and Herwatz (2006).
As far as I understand it correctly, the shocks have to be independent and non-normal to be unique.
If these two conditions have to be met, in addition to a non-normality test, shouldn't independence of the residuals resulting from the BEKK model be tested?
Could you give me a suggestion of a procedure that tests the independence between the residulas resulting from the BEKK model?
In the literature I just see normality tests and univariate tests, but no tests that test for joint independence of the elements of the residual vector.
Thank you in advance
Kind regards
Jules
Kind regards
Jules
