Error on SVAR-GARCH impulse response
Posted: Wed Feb 19, 2020 6:11 pm
Dear Tom Doan
I followed the example 11.2 SVAR_GARCH impulse response in RATS handbook for ARCH/GARCH and Volatility model(2nd Edition)
But I have a error massage because of below the code In the example
* This computes the logl likelihood by computing the covariance
* matrix, then the square root of the oil shock variance, then the
* residuals. It has to be done in that order since current sqrthoil
* is needed in the formula for the residuals.
frml SAVRLogl = hh=SVARHMatrix(t),sqrthoil=sqrt(hh(t)(1,1)),$
ux=SVARUVector(t),%logdensity(hh,ux)
## SX11. Identifier SVARHMATRIX is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>l = hh=SVARHMatrix(<<<<
Common errors are
* a space before the ( in an option field
* a missing space before = in a SET or FRML
* a missing $ at the end of a long line which continues to the next
Would you please give me right answer to fix it?
Above code is similar to the code in example 11.1 SVAR-GARCH-M estimation
frml garchmlogl = hhv=SVARHVMatrix(t),sqrthoil=sqrt(hhv(t)(1,1)),$
vx=bb*%xt(y,t)-SVARRHSVector(t),vv=%outerxx(vx),$ %logdensity(hhv,vx)
The code in 11.1 works! So, I used it But I have a same error like above
Regards
Common errors are
Regards
