BOXJENK output
Posted: Sun Feb 16, 2020 11:02 am
Working on an example of what happens when you model a nonstationary series as trend stationary. Running this code:
This is the output:
Why is variable 4 not identified as "trend"?
Thank you.
boxjenk(constant,ar=1,ma=1,define=gdpmodel,regressors,maxl) lgdp startdate enddate
#trendCode: Select all
Box-Jenkins - Estimation by ML Gauss-Newton
Convergence in 16 Iterations. Final criterion was 0.0000067 <= 0.0000100
Dependent Variable LGDP
Quarterly Data From 1995:01 To 2011:04
Usable Observations 68
Degrees of Freedom 64
Centered R^2 0.9976231
R-Bar^2 0.9975117
Uncentered R^2 0.9999996
Mean of Dependent Variable 9.5225398422
Std Error of Dependent Variable 0.1281958299
Standard Error of Estimate 0.0063948371
Sum of Squared Residuals 0.0026172123
Log Likelihood 247.3154
Durbin-Watson Statistic 1.7413
Q(17-2) 23.8108
Significance Level of Q 0.0683775
1. CONSTANT 8.0812375566 0.2014403560 40.11727 0.00000000
2. AR{1} 0.9761351790 0.0294054725 33.19570 0.00000000
3. MA{1} 0.2822992057 0.1237816244 2.28062 0.02590984
4. 0.0062448958 0.0009017912 6.92499 0.00000000
Thank you.
