ARDL, Long-run response, and hypothesis tests
jhusein
I'm estimating quiet few ARDL models and the example/program distriblag.rpf was very helpful. Assuming I'm doing it right and
After extracting the long-run response for example of Y to X1 via
compute arpoly=%eqnlagpoly(0,Y)
compute dlpoly=%eqnlagpoly(0,X1)
compute ardlpoly=%polydiv(dlpoly,arpoly,#)
I'm trying to test first if the long-run response is ZERO and second if the Long-run response is unity.
I appreciate if you (or anyone's) help with the proper test command(s) in RATS to do this? Thanks.
Jamal
Jamal
Re: ARDL, Long-run response, and hypothesis tests
You can use SUMMARIZE to do that. (You have to write the function in terms of the %BETA coefficients). See, for instance, the Harvey textbook example harveyp393.rpf.
<edit>
Upon further review, you can actually do this directly if all the calculations are done in one go:
summarize(numerical) %polyvalue(%eqnlagpoly(0,shortrate),1.0)/%polyvalue(%eqnlagpoly(0,longrate),1.0)
(The %eqnlagpoly functions are the ones that implicitly use the %BETA,so they can't be computed separately from the SUMMARIZE instruction).
<edit>
jhusein
Many thanks and Yes, all calculations are done in one go.TomDoan wrote:You can use SUMMARIZE to do that. (You have to write the function in terms of the %BETA coefficients). See, for instance, the Harvey textbook example harveyp393.rpf.
<edit>
It works for testing long run response is zero.
Can "summarize" be modified to test if long run response is unity though?
You can do a test for a long-run value of 1 with
summarize(numerical) %polyvalue(%eqnlagpoly(0,shortrate),1.0)/%polyvalue(%eqnlagpoly(0,longrate),1.0)-1.0
Last bumped by TomDoan on Fri Jul 12, 2024 4:39 pm.
