Page 1 of 4
Rolling-VAR-MGARCH-M
Posted: Sat Sep 01, 2018 10:40 am
by hasanov
The objectives of the code in the attached .RPF file are as follows:
- to estimate VARMA-MGARCH-in-mean model through the rolling windows where the fixed window size is 1250 and increment is 5.
- to generate 5-step ahead volatility forecasts in each window and save these series in hhat11 and hhat22 objects.
- this code also saves some of estimated coefficients from each regression in coef1, coef2, and coef3 objects.
I would be appreciated if anyone could check the code whether everything is OK. I suspect the mean model (i.e., VARMA) and var-cov model (i.e., MGARCH-M) use different sample periods.
Attached is the code file.
Many thanks
set rvar1 = 100.0*(log(var1)-log(var1{1}))
set rvar2 = 100.0*(log(var2)-log(var2{1}))
set rvar3 = 100.0*(log(var3)-log(var3{1}))
source mvgarchfore.src
compute d=1250
dec series hhat11
dec series hhat22
dec series hhat33
dec series hhat12
dec series hhat13
dec series hhat23
clear hhat11
clear hhat22
clear hhat33
clear hhat12
clear hhat13
clear hhat23
clear coef1 coef2 coef3 coef4 coef5
clear tstat1 tstat2 tstat3 tstat4 tstat5
clear conv iter
dec vect[series] sqrth(3)
dec vect[series] eps(3)
dec symm[series] hhs(3,3)
clear(zeros) hhs
do regend = 2013:01:09, 2019:05:31, 5
equation oil_eq rvar1
# constant sqrth(1) sqrth(2) sqrth(3) rvar1{1} rvar2{1} rvar3{1}
equation rvar2_eq rvar2
equation rvar3_eq rvar3
group varmah oil_eq rvar2_eq rvar3_eq
clear(zeros) sqrth eps
do iters=1,3
   estimate(model=varmah,resids=resids)
   set eps(1) %regstart() * = resids(1)
   set eps(2) %regstart() * = resids(2)
   set eps(3) %regstart() * = resids(3)
end do iters
compute cv0=%sigma
garch(model=varmah, mv=bekk, robust, distrib=norm, rvectors=rv, hmatrices=hh, mvhseries=hhs, pmethod=simplex, piters=15, cvcrit=0.0001, iters=1000, presample=cv0,$
    uadjust=%pt(eps,t,rv(t)),hadjust=%(sqrth(1)=sqrt(hhs(1,1)), sqrth(2)=sqrt(hhs(2,2)), sqrth(3)=sqrt(hhs(3,3)))) regend-d+1 regend rvar1 rvar2 rvar3
@MVGarchFore(MV=BEKK, steps=5) hh rv
do i=1,5
compute hhat11(regend+i) = hh(regend+i)(1,1)
compute hhat22(regend+i) = hh(regend+i)(2,2)
compute hhat33(regend+i) = hh(regend+i)(3,3)
compute coef1(regend) = %beta(9)
compute coef2(regend) = %beta(10)
compute coef3(regend) = %beta(11)
compute coef4(regend) = %beta(38)
compute coef5(regend) = %beta(44)
compute tstat1(regend) = %tstats(9)
compute tstat2(regend) = %tstats(10)
compute tstat3(regend) = %tstats(11)
compute tstat4(regend) = %tstats(38)
compute tstat5(regend) = %tstats(44)
compute conv(regend) = %converged
compute iter(regend) = %ITERS
end do regend
print / coef1 tstat1 coef2 tstat2 coef3 tstat3
print / coef4 tstat4 coef5 tstat5
print / hhat11 hhat22 hhat33
print / conv iter
Re: Rolling-VAR-MGARCH-M
Posted: Mon Sep 03, 2018 8:04 am
That would be fine except that you're doing an asymmetric BEKK and there is no closed form forecasting procedure for an asymmetric BEKK.
Posted: Mon Sep 03, 2018 8:24 am
by hasanov
Thanks Tom!
How about the forecasts generated by procedure (i.e., @MVGarchFore(MV=BEKK, steps=5) hh rv) in the code? Does this procedure ignore the asymmetric component and produce forecasts?
Regards
Posted: Mon Sep 03, 2018 8:37 am
Correct. Because it does the closed-form calculation, it ignores the asymmetry, but your estimates include it, so the forecasts won't be correct.
Note, by the way, that your model has a lot of quite insignificant coefficients, particularly in the mean model. Pick the mean model that's appropriate for your data, not someone else's.
Posted: Mon Sep 03, 2018 8:57 am
by hasanov
Many thanks for your prompt reply. Actually, the data is used for preliminary coding purposes. We plan to use the code for different set of data.
Kind Regards,
Posted: Mon Sep 10, 2018 8:49 am
by hasanov
It is clear that
%BETA - vector for the coefficients
%TSTATS - t-stats for the coefficients
%STDERRS - vector of coefficient standard errors
How about the p-values? Is there any specific vector for p-values?
Posted: Mon Sep 10, 2018 9:02 am
No. But you can get those from the t-stats fairly easily. Note, BTW, that "rolling sample" GARCH models are really not a good idea. Fixing the start, and moving the end to do simulated out-of-sample forecasts has some value. Moving the start along with the end isn't well-motivated.
Posted: Tue Dec 11, 2018 12:14 am
by hasanov
In the procedure below:
@MVGarchFore(MV=BEKK, steps=1) hh rv
Does rv contain fitted values of returns or errors?
How elements of rv vector can be extracted? What commands can be used?
Many Thanks
Posted: Tue Dec 11, 2018 9:28 am
No. RV is input to the procedure---it should be what's produced by the RVECTORS option on GARCH. (Lagged residuals are needed to compute the out-of-sample forecasts).
Posted: Sun Dec 16, 2018 3:27 am
by wert12
Dear hasanov, i would be most grateful if you could send me the data file.txt?
Posted: Thu Apr 25, 2019 8:00 pm
by hasanov
I need to gather the convergence info for each rolling sample estimation and want to store it in a separate vector.
For example, coefficients are stored in %beta? Is there any object in RATS to store the convergence info?
I just need Yes" or "No" info for the numerical convergence for each rolling sample estimation.
Many thanks
Posted: Thu Apr 25, 2019 10:51 pm
Posted: Sun Apr 28, 2019 11:49 pm
by hasanov
Once the rolling estimation has been done, I used "print / " option to get the results gathered in "ceof" and "hhat11". But it only shows the part of the results, not all of the results. How can I set to print all the results?
Many thanks
Posted: Mon Apr 29, 2019 8:25 am
You have an active SMPL (which, so far as I can tell you never actually use):
smpl regend-d+1 regend roilf
smpl regend-d+1 regend rheatoilf
but that will affect a PRINT / ... instruction. So far as I can tell, you don't need those at all. (Note also that those third parameters on the SMPL's aren't part of the command and are ignored---I'm not sure what you intend those to mean).
Posted: Wed May 15, 2019 10:32 am
by hasanov
How can I obtain univariate or multivariate auto correlation test statistic for each window and store them in a separate object? Is it possible in RATS? Your advice is highly appreciated.
Thank you
