Calculating annual average growth rates in a panel
Marcus
So using the Penn World Tables, I tried to calculate these growth rates. I expected to get one value for each country/cross section unit but my "best" attempt gave me one value for each year.
Here's a code that not even produced the values for each year.
Any help on this would be greatly appreciated.
/Marcus
OPEN DATA "H:\My Documents\gamlalocal\Makro\Penn\pwt90forrats.xlsx"
CALENDAR(PANELOBS=65,A) 1950:1
DATA(FORMAT=XLSX,ORG=COLUMNS,SHEET="Data") 1//1950:01 182//2014:01 c_number year rgdpe rgdpo pop emp avh $
hc ccon cda cgdpe cgdpo ck ctfp cwtfp rgdpna rconna rdana rkna rtfpna rwtfpna labsh delta xr pl_con $
pl_da pl_gdpo csh_c csh_i csh_g csh_x csh_m csh_r pl_c pl_i pl_g pl_x pl_m pl_k
set id = c_number
set timeid = year
do i = c_number, pl_k
set temp = i{0}
pform(indiv=c_number,time=timeid) i
# temp
set smpl = 1970, 2014
set rgdepop = rgdpe/pop
set rgdopop = rgdpo/pop
dofor i = rgdepop rgdopop
compute [label] l = "l"+%l(i)
set %s(l) = 100*( (( [series] i (2014:1)/ ([series]i) (1970:1))^.02222 ) -1.0)
/Marcus
set id = c_number
set timeid = year
set temp = i{0}
# temp
Re: Calculating annual average growth rates in a panel
It looks like it should give you repeated values for each entry for a country. Is that what you're getting? You want that reduced to just show one value for each country?
Marcus
Yes, the idea was to get just one value for each country, the annual average growth rate between 1970 and 2017 and then make a scatter graph with that on the y-axis and the 1970-value on the x-axis
