How to check the underlying codes of an instruction?
applej
Unread post by applej »
Hi, Tom,
Is it possible to check the codes underlying an instruction, say " correlate(option)"?
Thank you,
J
Re: How to check the underlying codes of an instruction?
No. Only procedures, not built-in instructions. The technical description of how CORRELATE works is described at https://estima.com/ratshelp/autocorrelations.html.
