Confidence Interval Data of VAR model
Posted: Wed Nov 09, 2016 9:54 pm
by bok1234
Dear Mr.Doan
I want to draw ALL graphs which I posted a few days ago, ‘with EXCEL’, not copying RATS graphs.
'ALL graphs' means not only IRF but also confidence intervals of each panel.
To do this, I need whole numbers of not only every IRF (black line) but also every confidence interval (CI) limits (blue lines). In the case of IRFs, they can be got if ‘noprint’ option is deleted in ‘IMPULSES.RPF’. However, CIs cannot be done through this way. I tried one poor action – deleting ‘noprint’ option in ‘montevar.src’. The result was disaster – just the pages of output got exploded. Would you show me the way how to get the data of upper and lower limits of CIs in every IRF graph panel?
Re: Confidence Interval Data of VAR model
Posted: Thu Nov 10, 2016 9:14 am
Replace the @MONTEVAR with the combination of
@MCVARDODRAWS (which does the Monte Carlo integration) and
@MCPROCESSIRF (which analyzes the draw information and produces the limits). You can then do a COPY instruction to get the information into an Excel file.
@mcvardodraws(model=canmodel,draws=4000)
@mcprocessirf(model=canmodel,lower=lower,upper=upper,center=median,irf=irfs)
copy(format=xls,org=columns) / irfs upper lower
close copy
Posted: Mon Nov 14, 2016 1:32 am
by bok1234
Dear Mr.Doan,
Yes, 2 procedures replacing @montevar in 'impulses.rpf' produce successfully excel data of IRFs & CI.
Thank you for your speedy answer as usual.
I was out of office for 3 days, so late for testing your code.
Posted: Tue Nov 28, 2017 7:35 am
by bok1234
Dear Mr.Doan,
In cases of @MONTEVAR, @MCVARDODRAWS, and @MCPROCESSIRF, every shock is 1 standard deviation of each variable?
Posted: Tue Nov 28, 2017 11:19 am
@MCPROCESSIRF doesn't do anything but process output from something else that generates responses.
By default,
@MONTEVAR and
@MCVARDODRAWS do unit shocks in the Cholesky factor, which means one standard deviation in each of the orthogonalized shocks, which is
not the same as one standard deviation in each variable, except for the first variable in the system. If you want something else, you can use the FFUNCTION option.
Posted: Mon Mar 26, 2018 5:16 pm
by Thao NGUYEN
TomDoan wrote:Replace the @MONTEVAR with the combination of
close copy
I'm trying to estimate a panel VAR with shrinkage estimators. How can I draw the confidence bands for the impulses responses accumulated in a panel VAR? Could I use @MCVARDODRAWS?
Many thanks.
Nguyen.
Posted: Tue Mar 27, 2018 12:48 pm
