SVAR Error messages and saving results
Posted: Tue Aug 23, 2016 10:00 am
The attached rats prg is a SVAR file using the dataset.
In the code, when I run the below, I have error message.
system(model=varhousepr) 1 to 6
VAR rtrade dlgdp infl dlrhopr drexc rdom
*VAR rtrade dlpcon infl dlrhopr drexc rdom
lags 1 to 4
det constant DU92Q3 DU93Q1 DU95Q4
Do you know how to fix it?
Also,
When I run @VARIRF(model=varhousepr,steps=40,DECOMP=f,byshock,errors),
I also have error message.
When I delete "byshock" in the command, it runs. Is is ok?
Also, I would like to save the results of impulse responses (including 5 and 95% confidence bands).
Please let me know how to do it.
Thank you very much!
lags 1 to 4
Also,
