Smoothed and Unsmoothed Regime Probabilities TVTP Filardo
Posted: Tue Aug 09, 2016 9:16 am
by Jules89
Hello Tom,
I have rewritten the Filardo (1994) paper replication for maximum likelihood.
The code is below:
************************* Reading in and Transforming the Data *************************
cal(m) 1948
open data filardo.dat
stats(noprint) ipgr * 1959:12
stats(noprint) ipgr 1960:1 *
set g = ipgradjust
set cligr   = 100.0*log(cli/cli{1})
set spgr    = 100.0*log(sp/sp{1})
set xlidiff = xli-xli{1}
set ffdiff  = fed-fed{1}
* Center variabes to zero means
   diff(center) s
end dofor s
**************************** Setting up the Markov Switching Constant TP ****************************
**************************** Setting up the Markov Switching ****************************
source msvarsetup.src
compute nlags=4
@MSVARSetup(lags=nlags, Switch=M)
# g
nonlin(parmset=common) mu phi sigma
******************** Time varying probabilities **********************
dec equation p1eq p2eq
dec vector   v1   v2
nonlin(parmset=tv) v1 v2
********** Overwriting the standard fixed transition matrix **********
function  %MSVARPmat  time
type rect %MSVARPmat
type int  time
local integer i j
local rect    pexpand
local real    z
if nexpand==nstates {
   compute %MSVARPmat=pexpand*p
else {
******* Initialize the probabilities using only the intercepts *******
function TVPInit
type vector TVPInit
local rect a
local integer i j
compute TVPInit=%MSVARInit()
********************* Calculating the Likelihood *********************
****************** Initialize the other Parameters *******************
@MSVARInitial
*** Define the logistic index for the transitions
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
***Starting Values Except Sigma (initialized in @MSVARInitial)
compute v1=log(.7/.3)~~0.0
compute v2=log(.95/.05)~~0.0
compute mu(1)=-1.7,mu(2)=.3
**************** Maximization of the Log-Likelihood *****************
 method=bfgs) logltvtp gstart gend
What I now want to do is plotting the filtered and the smoothed Probabilities of the two states. Here is my code for that:
****************** Plotting the Regime Probability ******************
@msvarsmoothed gstart gend psmooth
set prs1 gstart gend = PSMOOTH(t)(1)
set prs2 gstart gend = PSMOOTH(t)(2)
set pr1 gstart gend = pt_t(t)(1)
set pr2 gstart gend = pt_t(t)(2)
spgraph(vfields=2)
graph(style=line, header="Probability State 1 Unsmoothed")
# pr1
graph(style=line, header="Probability State 2 Unsmoothed")
# pr2
spgraph(vfields=2)
graph(style=line, header="Probability State 1 Smoothed")
# prs1
graph(style=line, header="Probability State 2 Smoothed")
# prs2
What you can see from the filtered (Unsmoothed) probabilities is that the two states do not add up to one. What did I do wrong?
Thank you very much in advance
Jules
Re: Smoothed and Unsmoothed Regime Probabilities TVTP Filard
Posted: Tue Aug 09, 2016 2:12 pm
The pt_t and pt_t1 are the probabilities of the augmented regimes (in this model the 32 possible combinations of regimes from t to t-4.) You need to marginalize that to get the current regime only. For instance,
set pr1 gstart gend = %MSVARMarginal(pt_t(t),0)(1)
set pr2 gstart gend = %MSVARMarginal(pt_t(t),0)(2)
The @MSVARSmoothed already takes care of that for the smoothed probabilities.
Posted: Wed Aug 10, 2016 1:58 am
by Jules89
Thank you so much!
This software has great support!
Best Jules
