Combinatorics
Posted: Wed May 06, 2009 7:23 am
by jonasdovern
Dear RATS-user,
does anybody have a nice piece of code to "run through" the possible combinations of a "n choose k" problem? Say I have an index of dimension N pointing to a set of regressors. Now, I would like to estimate all equations that have possible combinations of k of those regressors as explanatory variables. I guess I have to do multiple loops over n=1,N. Any hint on how to program this efficiently? Best, Jonas.
*My guess for structure of the code:
decl vec[int] reglist
decl vec[equ] eqn(%factorial(N)/(%factorial(k)*%factorial(N-k))
comp counter = 1
* Some part of the loop-structure
comp reglist = %rlempty()
* Fill reglist with new combination of regressors
linreg(define=eqn(counter)) depvar
# constant reglist
compute counter=counter+1
* Close all loops
Re: Combinatorics
Posted: Wed May 06, 2009 9:26 am
The code below is something relatively close. If all you really need out of the regressions is the sum of squared residuals, you can do that with:
LINREG Y
# list of all X's
CMOM(LASTREG)
loop from below generating combinations
COMPUTE SXX=%SWEEPLIST(%CMOM,PICK)
COMPUTE RSS=SXX(%NCMOM,%NCMOM)
do something with RSS
finish loop
end loop
* This code sample demonstates a method for selecting a valid set of
* instruments for a GMM where some of the moment conditions are suspected
* of being incorrect.
* It is based on a recent paper by Donald Andrews, entitled "Consistent
* Moment Selection Procedures for Generalized Method of Moments Estimation."
* Econometrica, Vol. 67, No. 3, pp 543-564. To do this precisely as
* described by Andrews requires running GMM with all subsets of a given
* size out of the instrument set. The following code provides a systematic
* method for generating such subsets.
* Most of the code is written to be as general as possible. In this
* particular example, we demonstrate the use of the "pos" index to set
* up MASK arrays for a GMM estimated using the NLSYSTEM command.
* Note that this is not a complete program--you need to add instructions
* to read in your data, do any transformations, etc. For the NLSYSTEM case,
* as shown here, you will also need to define your non-linear parameters,
* and define the formula to be estimated (we refer to it as "mygmmfrml"
* in the NLSYSTEM command included below):
* The sections of code specific to this application (i.e. the sections
* which need to be changed for other applications) are bracketed
* by "*******************" lines.
* Written by Estima
* August, 1999
declare vect[int] pos
* pop is the population size (10 in this example)
* pick is the number of items to be picked
compute pop =10
compute pick=5
dim pos(pick)
* Variable definitions specific to this example:
* Set up the MASK array to be used for this particular application:
dec rect mask(pop,1)
* Initialize bookkeepping variable:
compute bestuzwzu=-1.0
* End of application-specific variable definitions
* start with 1,2,...,pick. The vector of integers "pos" is always filled with an increasing
* sequence of values between 1 and pop.
ewise pos(i)=i
compute fixpos=pick
begin {
loop {
* Insert code here to do what you want with the indexes in pos. In this example, we
* specify the masking arraying and estimate using NLSYTEM:
compute mask=%const(0.0)
do j=1,pick
compute mask(pos(j),1)=1.0
nlsystem(mask=mask,zudep,instruments,noprint) / mygmmfrml
if bestuzwzu<0.or.%uzwzu<bestuzwzu
compute bestuzwzu=%uzwzu,bestset=pos
* End of inserted code section
* When we hit the end of the range for a slot,
* back up to the nearest preceding slot which still
* can be incremented.
while (fixpos>=1.and.pos(fixpos)==pop+fixpos-pick)
compute fixpos=fixpos-1
* If all slots are at their limit, we're done.
if fixpos==0
break
* Increment the selected slot by one, and set all
* following slots to their preceding slot plus one.
compute pos(fixpos)=pos(fixpos)+1
do j=1,pick-fixpos
compute pos(fixpos+j)=pos(fixpos)+j
compute fixpos=pick
Re: Combinatorics
Posted: Thu May 07, 2009 4:42 am
by jonasdovern
Thanks for the example code. I could adjust it to my problem. I think, however, your code is missing one combination, namely the initial
specification. You end up with only pop!/(pick!(pop-pick)!)-1 combinations! I adjusted that by including a counter and added the statement
just before the
statement. Best, Jonas
