INQUIRE incorrectly calculates ending date
Posted: Thu Mar 03, 2016 6:14 pm
I have code that, for performance reasons, inserts data into a nested hash and passes that hash into a procedure. I've run into strange behaviour, though, when using the INQUIRE instruction in that INQUIRE calculates the ending date of the series incorrectly. Here is a contrived example:
Data are attached. This displays
The end date of 2004:04 is clearly incorrect. I'm using the newest build of RATS that's available (from the forum post earlier this week).
calendar(q) 1950 1
allocate 2050:4
procedure testproc data
type hash[series] data
option integer maxlags 8
* unpack data
smpl 1969:1 2004:4
set lgdpk = data("lgdpk")
set lcnsk = data("lcnsk")
set lcotherk = data("lcotherk")
set dlp = data("dlp")
set dlpxfe = data("dlpxfe")
* determine start and end points
local integer begin_est end_est
inquire(regressorlist) begin_est end_est
# lgdpk {0 to maxlags} lcnsk{0 to maxlags} lcotherk{0 to maxlags} dlp{0 to maxlags} dlpxfe{0 to maxlags}
print 2000:1 2006:4 lgdpk lcnsk lcotherk dlp dlpxfe
display %datelabel(begin_est) %datelabel(end_est)
* load data
open data "sandbox_data.xls"
data(format = xls, org = columns) 1969:1 2004:4 lgdpk lcnsk lcotherk dlp dlpxfe
close data
* insert data into hash
declare hash[series] %data
declare string lbl
dofor lbl = "lgdpk" "lcnsk" "lcotherk" "dlp" "dlpxfe"
set %data(lbl) 1969:1 2004:4 = %s(lbl)
clear %s(lbl)
end dofor lbl
@testproc(maxlags = 8) %data
ENTRY LGDPK LCNSK LCOTHERK DLP DLPXFE
2001:01 9.1302035 8.6943927 8.2677455 0.00818734 0.00695187
2001:02 9.1262085 8.6965609 8.2541511 0.00447919 0.00295149
2001:03 9.1254794 8.6991537 8.2482163 -0.00018243 0.00184027
2001:04 9.1322491 8.7056394 8.2554324 0.00200492 0.00677969
2002:01 9.1445424 8.7166708 8.2697190 0.00272752 0.00355467
2002:02 9.1476561 8.7209864 8.2709173 0.00678644 0.00462943
2002:03 9.1575301 8.7256222 8.2891890 0.00422948 0.00442778
2002:04 9.1609610 8.7333526 8.2856954 0.00456929 0.00377970
2003:01 NA NA NA NA NA
2003:02 NA NA NA NA NA
2003:03 NA NA NA NA NA
2003:04 NA NA NA NA NA
2004:01 NA NA NA NA NA
2004:02 NA NA NA NA NA
2004:03 NA NA NA NA NA
2004:04 NA NA NA NA NA
2005:01 NA NA NA NA NA
2005:02 NA NA NA NA NA
2005:03 NA NA NA NA NA
2005:04 NA NA NA NA NA
2006:01 NA NA NA NA NA
2006:02 NA NA NA NA NA
2006:03 NA NA NA NA NA
2006:04 NA NA NA NA NA
1969:01 2004:04
