Compare IRF results from different studies
Posted: Wed Jan 27, 2016 2:54 pm
I try to compare the impulse responses from different studies. However, I am not sure if my conclusions are correct. This is my problem:
Two studies that use monthly data report the responses of stock returns to a shock in oil prices. Both studies use vector autoregressive models and then construct impulse responses with a 1 standard deviation shock in oil prices. Now I want to compare both studies and thus I look (for example) at the response after 3 months. However, I am not sure if I can directly compare the absolute values of the responses? Or do I have to know the standard deviation for the oil price time series from both studies and then I can compare 0.0017/SD_1 (first study) with -0.01/SD_2 (second study)?
Why is the size of the shocks usually not given in absolute values (e.g., a 10% shock in oil prices)? If I would know that the shock in the first IRF is 10% and in the second its 20%, then I could divide the second response by 2 and then both values for the IRFs after 3 months should be directly comparable?
This figure illustrates my problem:
Thanks a lot for your help!
