Diagnostic Testing of SVAR using Monte Carlo Integration
Posted: Thu Jan 07, 2016 6:58 am
by sanjeev
Respected Sir
I am using Structural VAR model with Monte Carlo Integration to derive my results. My question is: whether I need to do "diagnostic testings" in this case.
if yes, then which tests need to be applied?.
Regards
Re: Diagnostic Testing of SVAR using Monte Carlo Integration
Posted: Thu Jan 07, 2016 7:46 am
Diagnostic tests of what? If you're doing some form of Gibbs sampling, you would want to do standard diagnostics on the chain to see if has a reasonable degree of "forgetfulness". If you're talking about diagnostic tests for the model itself, that's not what MC integration is designed to do.
Posted: Fri Jan 08, 2016 4:41 am
by sanjeev
Yes I am talking of about diagnostic tests for the model itself.
I explained to my supervisor that in case of MC integration, diagnostic tests for the model is not required. She asked me to support my argument with some reference . Sir,
Can you please suggest me some paper or book so that I can support the point that "in case of MC integration, diagnostic tests for the model is not required".
Thanks and Regards
Posted: Fri Jan 08, 2016 10:23 am
sanjeev wrote:Yes I am talking of about diagnostic tests for the model itself.
Thanks and Regards
I can't because that's a complete misinterpretation of what I said. If the model is wrong, MC integration isn't some magic bullet that fixes it---you're just doing simulation analysis around a flawed model. Formal hypothesis testing using MC Bayesian analysis is
extremely difficult and requires that you are able to do MC analysis on a range of alternative models. You should do the testing based upon ML estimation and LR tests. If the LR test on CVMODEL strongly rejects your model, fix the model.
Posted: Sat Jan 09, 2016 5:22 am
by sanjeev
Yes Sir, I have already applied LR test based on ML estimation, that did not reject my model.
I just want to know whether I now need to do diagnostic testing i.e. test for autocorrelation and test for hetroscendasticity ???
Thanks and Regards
Posted: Mon Jan 11, 2016 12:38 pm
If you used a reasonable procedure for picking lag length, there probably is no reason to test for residual autocorrelation, though it certainly doesn't hurt. Generally, you don't test a VAR for heteroscedasticity simply because there isn't much that you can do about it if you find it.
