OLS with restrictions
Posted: Wed Oct 21, 2015 5:28 pm
I am replicating the econometric analysis of a published paper in which RATS was used. I am using MATLAB and other statistical tools for the purpose of replication. I have been able to match almost all numbers except for cases when a restriction is imposed on a linear regression using "restrict".
For example, in the following analysis,
linreg(robusterrors,damp=0,lags=n-1) y / res
#constant x1 x2 x3
restrict(create) 1
#2
#1 1
I can match the results completely for the unrestricted regression. I evaluated the restricted regression by regressing y-x1 on an intercept, x2 and x3 and the results do not match with the numbers from RATS. I also used the closed form expression for restricted least squares and they still don't match with RATS even though my own numbers are the same in both cases. (My numbers match with results from other statistical software that use built-in functions). Could there be an explanation for this mismatch? The original analysis was performed in 2006 and used the version of RATS available then. Any help would be highly appreciated! Thanks.
#constant x1 x2 x3
restrict(create) 1
#2
#1 1
