Regarding serial correlation on RATS for the VAR
Posted: Thu Sep 10, 2015 2:00 pm
I am trying to test for serial auto correlation in the residuals after estimating the var. I used
@mvqstat(lags=p)
# residuals
(where p=4)
And I get the output as
Multivariate Q(4)= 27.54972
Significance Level as Chi-Squared(100)= 1.00000
I guess that the first line shows the Q statistic with the number of correlations tested (here 4). The second shows the significance level and the degrees of freedom.
So what would this mean then? That there's no serial correlation in the residuals?
Also what if I want to perform the BG LM test for serial correlation on RATS for the VAR ? Could you tell me how to do that?
Many Thanks
@mvqstat(lags=p)
# residuals
(where p=4)
Many Thanks
