Setting up an unbalanced Panel Dataset in RATS
Posted: Thu Jun 25, 2015 12:42 pm
Dear All,
I have the following daily dataset (318 609 obs) in Stata's dta format and from which I am including a sample:
For some reason I am not able to have RATS read in the data using either the smaller or the full sample. Sometimes I get an error memory message, sometimes the processing data window stays on but nothing seems to happen. Does anyone have an idea what is going on?
thank you.
I am trying to read the data into RATS using the following code:PERMNO Date Date2 SIC1 SIC2 Price Val_Weight_Ret_incl_div Val_Weight_Ret_excl_div Eq_Weight_Ret_incl_div Eq_Weight_Ret_excl_div S_P_500_Ret
10145 19950103 1/3/95 3724 3714 34 -0.002393 -0.002426 0.004019 0.00399 -0.000348
10145 19950104 1/4/95 3724 3714 33.875 0.003319 0.003086 0.004864 0.00479 0.003485
10145 19950105 1/5/95 3724 3714 34.25 -0.000107 -0.000194 0.00306 0.003035 -0.000803
10145 19950106 1/6/95 3724 3714 34.375 0.00181 0.001804 0.00457 0.004551 0.000739
10145 19950109 1/9/95 3724 3714 34.125 0.001053 0.000885 0.002696 0.002473 0.000326
10145 19950110 1/10/95 3724 3714 34.75 0.002064 0.002035 0.001391 0.001341 0.001844
10145 19950111 1/11/95 3724 3714 35 -0.000447 -0.00046 0.00052 0.000503 -0.000022
10145 19950112 1/12/95 3724 3714 35.125 0.000179 0.000177 0.003075 0.003064 -0.000065
10145 19950113 1/13/95 3724 3714 35.5 0.008543 0.008378 0.00769 0.007606 0.00938
10145 19950116 1/16/95 3724 3714 36 0.007831 0.007831 0.004495 0.004494 0.007318
10145 19950117 1/17/95 3724 3714 36.125 0.002274 0.00223 0.003545 0.003505 0.001427
10145 19950118 1/18/95 3724 3714 36.125 -0.001145 -0.001156 0.000922 0.000892 -0.000723
10145 19950119 1/19/95 3724 3714 36.125 -0.005347 -0.005374 -0.002178 -0.002194 -0.005876
10145 19950120 1/20/95 3724 3714 36.125 -0.004911 -0.004915 -0.000352 -0.000364 -0.004647
10145 19950123 1/23/95 3724 3714 36 -0.000379 -0.000445 -0.004954 -0.004986 0.002238
10145 19950124 1/24/95 3724 3714 36.75 0.001973 0.001908 0.003531 0.003509 0.000086
10145 19950125 1/25/95 3724 3714 36.5 0.002194 0.002019 0.000672 0.000535 0.003392
10145 19950126 1/26/95 3724 3714 36 0.000558 0.000488 0.000818 0.000745 0.001883
10145 19950127 1/27/95 3724 3714 35.625 0.003729 0.003712 0.002577 0.002561 0.00442
10145 19950130 1/30/95 3724 3714 35.75 -0.004428 -0.004589 -0.004205 -0.004296 -0.003997
10145 19950131 1/31/95 3724 3714 35.75 0.003961 0.003749 0.005332 0.005247 0.004077
10145 19950201 2/1/95 3724 3714 35.375 0.001844 0.001788 0.001533 0.001486 -0.000043
10145 19950202 2/2/95 3724 3714 35.75 0.00462 0.004489 0.004336 0.004288 0.005081
10145 19950203 2/3/95 3724 3714 37.25 0.012267 0.012207 0.007553 0.007526 0.012395
10145 19950206 2/6/95 3724 3714 37.875 0.006088 0.005691 0.004546 0.004418 0.005202
10145 19950207 2/7/95 3724 3714 37.625 -0.000432 -0.000515 0.002004 0.001941 -0.000686
10145 19950208 2/8/95 3724 3714 38 0.001454 0.001361 0.002784 0.002623 0.00079
13856 20130614 6/14/13 2086 2086 82.13 -0.005371 -0.005385 -0.004604 -0.004649 -0.005885
13856 20130617 6/17/13 2086 2086 82.55 0.007177 0.007168 0.005131 0.005119 0.007567
13856 20130618 6/18/13 2086 2086 82.57 0.007355 0.007314 0.006078 0.00599 0.007791
13856 20130619 6/19/13 2086 2086 80.89 -0.013406 -0.013426 -0.009639 -0.009747 -0.013851
13856 20130620 6/20/13 2086 2086 78.91 -0.025743 -0.025844 -0.023687 -0.023715 -0.02501
13856 20130621 6/21/13 2086 2086 80.13 0.001442 0.001353 0.002747 0.002466 0.00267
13856 20130624 6/24/13 2086 2086 80.13 -0.012324 -0.012423 -0.014795 -0.014937 -0.012145
13856 20130625 6/25/13 2086 2086 80.04 0.010326 0.010238 0.009985 0.009877 0.009497
13856 20130626 6/26/13 2086 2086 81.3 0.008921 0.00862 0.005205 0.004851 0.00959
13856 20130627 6/27/13 2086 2086 81.74 0.008115 0.007911 0.011708 0.011424 0.0062
13856 20130628 6/28/13 2086 2086 81.79 -0.002796 -0.002842 0.001627 0.001533 -0.00429
13856 20130701 7/1/13 2086 2086 82.04 0.006723 0.006619 0.009141 0.009039 0.005404
13856 20130702 7/2/13 2086 2086 81.68 -0.001399 -0.00157 -0.002919 -0.002982 -0.000545
13856 20130703 7/3/13 2086 2086 80.73 0.000415 0.000405 -0.0001 -0.00013 0.000824
13856 20130705 7/5/13 2086 2086 80.8 0.009014 0.008977 0.005947 0.005934 0.010202
13856 20130708 7/8/13 2086 2086 81.78 0.005172 0.004973 0.003698 0.003661 0.005252
13856 20130709 7/9/13 2086 2086 82.77 0.007715 0.007692 0.00576 0.005704 0.00723
13856 20130710 7/10/13 2086 2086 82.99 0.000643 0.000571 0.00277 0.002691 0.000182
13856 20130711 7/11/13 2086 2086 84.55 0.014621 0.014479 0.012997 0.012768 0.013554
13856 20130712 7/12/13 2086 2086 84.32 0.002473 0.002466 0.001028 0.001018 0.003087
13856 20130715 7/15/13 2086 2086 84.72 0.002323 0.002311 0.005546 0.00549 0.001375
13856 20130716 7/16/13 2086 2086 84.02 -0.003775 -0.003779 -0.001546 -0.001572 -0.003709
13856 20130717 7/17/13 2086 2086 85.24 0.002997 0.002918 0.003696 0.003633 0.002774
13856 20130718 7/18/13 2086 2086 86.8 0.00545 0.005376 0.00497 0.004945 0.005033
13856 20130719 7/19/13 2086 2086 86.41 0.00148 0.001454 0.000552 0.000538 0.00161
13856 20130722 7/22/13 2086 2086 86.4 0.002796 0.002774 0.004195 0.004138 0.002033
open data data_wrds1_upd1_test.dta
data(format=dta) 1 53 permno date date2 sic1 sic2 price Val_Weight_Ret_incl_div Val_Weight_Ret_excl_div $
pform(indiv=permno,time=date) p_vwrid
# Val_Weight_Ret_incl_div
thank you.
