Excessive piters?
Posted: Wed Aug 13, 2014 8:00 pm
Hi
I am running a multivariate garch model as specified by McAleer with varma variances. Statistics and analysis of univariate models suggest strongly the standardised residuals are non-norm so using robust errors.
My question relates to this, when I increase the number of initial iterations of an initial simplex procedure the significances change on my estimated coefficients. Their P value drops the more iterations used. I'm currently using 150. The log liklihood the bfgs method converges at also doesn't change.
Is there any harm in using excessive piters in model estimation?
Another question I have is with regard to checking specification. I've used the mvqstat to check residual corr in the standardised residuals and their squares. Because the mean equations are specied as univariate attachments would it be appropriate to ensure no resid corr in these using the regular ljung box test also?
Thank you for taking the time to read.
Oli
Oli
