Dynamic EGARCH forecast
Posted: Thu Aug 22, 2013 7:03 am
Hi, I'm using EGARCH model of Baillie, Bollerslev and Mikkelson(1996), "Fractionally Integrated Generalized Autoregressive Conditional Heteroskedasticity", the EGARCH code is from TomDoan,
what i'm trying to do is to forecast GBP's volatility dynamicly, the estimation window is 500, and rolling forward daily, until the full sample is reached.
but when i run the code, it writes:
The Error Occurred At Location 1509, Line 44 of loop/block
could someone help? many thanks here is my code:
all 3908
open data o:\GBP.xlsx
data(format=xlsx,org=obs) /
close data
set ph / = log(hi)
set pl / = log(lo)
set r / = (((ph-pl)**2.0)/(4*log(2)))**0.5
dofor tau2 = 1 5 20 60 120 240
comp step =fix(%IF(tau2>20,20,tau2))
comp tau1=fix(%max(1,tau2-19))
comp k=0
do i=500,3908-tau2, step
comp k=k+1
linreg(noprint) r i-499 i
#r{1 to 3}
frml(lastreg,vector=mu) meanf
compute omega=log(%seesq),delta=0.0
nonlin(parmset=meanparms) mu
clear u h
nonlin(parmset=garchparms) omega delta
frml varf = omega+log(1+delta*gap)
frml logl = u=r-meanf,h=exp(varf),%logdensity(h,u)
maximize(parmset=meanparms+garchparms) logl gstart gend
compute omega0=omega
nonlin(parmset=garchparms) omega delta psi1 phi1 phi2 theta gamma
compute psi1=-.8,phi1=1.0,phi2=0.0,theta=-.1,gamma=.2
compute uupresample=exp(omega0)
set uuadj = uupresample
set h = uupresample
set x = 0.0
set ax = 0.0
frml varf = omega+(1-phi1)*(1-phi2)*omega+$
log(1+delta*gap)-(phi1+phi2)*log(1+delta*gap{1})+phi1*phi2*log(1+delta*gap{2})+$
(phi1+phi2)*log(h{1})-phi1*phi2*log(h{2})+$
theta*(x{1}+psi1*x{2})+gamma*(ax{1}+psi1*ax{2})
frml logl = u=r-meanf,h=exp(varf),x=u/sqrt(h),ax=abs(x)-sqrt(2.0/%pi),%logdensity(h,u)
maximize(parmset=meanparms+garchparms,trace,iters=500) logl gstart gend
do j = tau1,tau2
set ract j j = r(i+j)
set rfor j j = exp(u+h+x+ax+%logdensity(h,u))
stat(noprint) ract tau1 tau2
set ractbar k k = %mean
stat(noprint) rfor tau1 tau2
set rforbar k k = %mean
linreg(noprint) ractbar 1 k
#constant rforbar
comp a=%beta(1);comp as=%stderrs(1)
comp b=%beta(2);comp bs=%stderrs(2)
comp rsq=%rsquared
test(noprint)
# 1 2
# 0.0 1.0
comp fstat=%cdstat
set error2 1 k = (ractbar-rforbar)**2.0
stat(noprint) error2 1 k
comp mse=(%mean*k/(k-1))**0.5
disp tau1 tau2 mse 100*a 100*as b bs rsq fstat
end dofor tau2
