Clark-McCracken test
Posted: Sun Feb 24, 2013 4:10 am
The interpretation of the Clark-McCracken test:
The null hypothesis is that there is no difference between the forecasting ability of the restricted and the unrestricted models. If the null is rejected, the unrestricted model yields better forecasts. Right?
But what if the forecasts of the unrestricted model are considerably worse than the forecasts of the restricted model, as in the example below? Is it possible to infer, for example on the basis of the MSF-F test statistic, that the forecast of the restricted model are significantly better than the forecast of the unrestricted model.
***Restricted model
In-sample 1988:01 - 2007:04
Out-sample 2008:01 - 2011:02
ME MAE RMSE MSE
-2.22828 3.64396 5.18879 26.92357
***Unrestricted model
ME MAE RMSE MSE
-0.69805 5.15850 6.57663 43.25203
Actual pi val = 0.17500
:nearest CM pi val = 0.20000
:second nearest CM pi val = 0.10000
number of restrictions in test = 4
**************************** test results ****************************
test test value asymptotic critical values (1-sided)
10% 5% 1%
MSF-F -5.285 1.184 1.864 3.258
MSF-t -1.241 0.781 1.142 1.766
ENC-F 0.358 0.990 1.410 2.287
ENC-t 0.690 1.186 1.595 2.208
***Restricted model
ME MAE RMSE MSE
ME MAE RMSE MSE
10% 5% 1%
