Programming for a large number of permutations
Posted: Mon Sep 24, 2012 2:55 pm
Hi there,
I am trying to estimate time-varying variance decompositions for 7 variables over 200-week rolling sample windows, using Cholesky factorization.
I wrote a program pasted at the bottom (based on the program shared at http://www.estima.com/forum/viewtopic.p ... old+yilmaz), but am getting two problems for which I need your help.
First, running the program returns a following error message.
Could you let me know how I should correct the program?
Second, I would like to repeat the process for 120 different orderings.
In the program below, you find I made two different orderings and a loop for them using dofor command:
However, what I need to do is a bit more complicated: among 7 variables (USA, EUR, KEN, TZA, UGA, RWA, BDI), I would like to fix USA and EUR at the first and second orders, respectively, and try all possible orderings among the other 5 variables.
It gives me 5! = 120 orderings.
It is next to impossible to establish 120 orderings as I do above.
Could you let me know how I can efficiently establish the 120 orderings and repeat the loop for the orderings?
Thank you so much for your support, and any advice is highly appreciated.
Masafumi
It is probably due to a following line, but I could not figure out how I can resolve this.## MAT13. Store into Out-of-Range Matrix or Series Element
The Error Occurred At Location 213, Line 12 of loop/block
set %s(%string(count)+"_from_"+%l(i)+"_to_"+%l(j)) end end = gfevd(j,i)(asteps)*100Second, I would like to repeat the process for 120 different orderings.
dec vect[int] order1
enter(varying) order1; # 1 2 3 4 5 6 7
dec vect[int] order2
enter(varying) order2; # 1 2 3 4 5 7 6
dofor order = order1 order2
Masafumi
* Replication file for Diebold and Yilmaz(2009), "Measuring Financial
* Asset Return and Volatility Spillovers, with Application to Global
* Equity Markets," Economic Journal, vol. 119, no. 534, 158-171.
* Analysis of returns data
* If you make usegirf=1, this will use the generalized spillover
* measures proposed in Diebold and Yilmaz(2011), "Better to Give than to
* Receive: Predictive Directional Measurement of Volatility Spillovers",
* IJF, to appear. usegirf=0 does the Choleski factorization used in the
* 2009 paper.
compute usegirf=0
OPEN DATA NEER_EAC.XLS
CALENDAR(W) 2000:1:9
DATA(FORMAT=XLS,ORG=COLUMNS,LEFT=2,DATEFORM="m/d/y") 2000:01:09 2012:09:09 $
R_USA R_EUR R_KEN R_TZA R_UGA R_RWA R_BDI
Labels 1 2 3 4 5 6 7
# 'USA' 'EUR' 'KEN' 'TZA' 'UGA' 'RWA' 'BDI'
* Produce the appropriate "factor" matrix from %sigma
function FactorMatrix
type rect FactorMatrix
if usegirf
compute FactorMatrix=%sigma*inv(%diag(%sqrt(%xdiag(%sigma))))
else
compute FactorMatrix=%decomp(%sigma)
* Creating different orders
* Rolling window analysis
compute nspan=200
* Width of rolling windows = 200 weeks
compute nsteps=10, asteps=4
* Compute variance decompositions up to 10 step and analyze the 4 step responses
compute rstart=2000:01:09, rend=2012:09:09
compute count = 0
compute count=count+1
do end=rstart+nspan-1,rend
* Setup and estimate one lag VAR
system(model=var)
variables order
lags 1
* Coefficients Restricted
compute coeffs = %modelgetcoeffs(var)
compute coeffs(3,1) = 0
compute coeffs(4,1) = 0
compute coeffs(5,1) = 0
compute coeffs(6,1) = 0
compute coeffs(7,1) = 0
compute coeffs(3,2) = 0
compute coeffs(4,2) = 0
compute coeffs(5,2) = 0
compute coeffs(6,2) = 0
compute coeffs(7,2) = 0
compute %modelsetcoeffs(var, coeffs)
estimate(noprint) end-nspan+1 end
compute gfactor=FactorMatrix()
errors(model=var,steps=nsteps,factor=gfactor,stderrs=gstderrs,noprint,results=gfevd)
do i=1,7
do j=1, 7
end do end
end dofor
