Estimate the TVTP-MS model with MSRegression
Posted: Mon Jul 30, 2012 9:29 pm
by samson
I estimated the FTP-MS model with @MSRegression you suggested previously, and it works!! (Thank you again for your kindly help :D )
Now I want to estimate the TVTP-MS model rather than FTP-MS model.
It seems that @MSRegression can also estimate the TVTP-MS model according to the description you made at
http://www.estima.com/forum/viewtopic.p ... 1208#p4302.
I found one example demonstrating the estimations with @MSRegression, but the transition probabilities in this example vary only with means.
(example:http://www.estima.com/forum/viewtopic.p ... t=30#p5340)
cal(d) 2006:03:24
open data "one_sample_ap.xls"
data(format=xls,org=cols) 2006:03:24 2012:03:05 apexcess aprm aprmsq logvix
sample(smpl=%valid(apexcess)) apexcess / apexcess_nomissing
sample(smpl=%valid(aprm)) aprm / aprm_nomissing
sample(smpl=%valid(aprmsq)) aprmsq / aprmsq_nomissing
sample(smpl=%valid(logvix)) logvix / logvix_nomissing
calendar(irregular)
compute gstart=1,gend=%nobs
@msregression(states=2,switch=ch) apexcess_nomissing
# constant aprm_nomissing aprmsq_nomissing
@msreginitial gstart gend
@MSFilterSetup(em)
nonlin(parmset=common) betas sigsqv
dec equation p1eq   p2eq
dec vector   v1     v2
dec vector   p1mean p2mean
nonlin(parmset=tv) v1 v2
* Define the logistic index for the transitions
equation p1eq *
# constant
equation p2eq *
# constant
dim p1mean(1) p2mean(1)
compute p1mean(1)=1.0,p2mean(1)=1.0
* Function to compute the transition probability matrix
function %MSPmat time
type rect %MSPmat
type int time
local integer i j
local rect pexpand
local real z
local rect p
dim p(1,2)
compute %MSInitTransition()
if nexpand==nstates {
   compute %MSPmat=pexpand*p
   ewise %MSPmat(i,j)=%if(i==nstates,1.0+%MSPmat(i,j),%MSPmat(i,j))
else {
   dim %MSPmat(nexpand,nexpand)
   ewise %MSPmat(i,j)=MSTransProbs(MSTransLookup(i,j))
* Initialize the probabilities using only the means
function TVPInit
type vector TVPInit
local rect a
local integer i j
dim p(1,2)
compute p(1,1)=%(z=exp(%dot(p1mean,v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(p2mean,v2)),1/(1+z))
compute TVPInit=%MSInit()
compute p=%MSPExpand(p)
procedure MSTVPEMEstimate start end
type integer start end
option integer iters 100
option real cvcrit 1.e-6
local integer emits time k
local series l11 l22 w11 w22
local vector baseparms testparms
local rect thisEntry
dim thisEntry(nstates,nstates)
compute baseparms=v1~~v2
do emits=1,iters
   compute %eqnsetcoeffs(p1eq,v1)
   compute %eqnsetcoeffs(p2eq,v2)
   compute TVPInit()
   @MSRegestep start end
   compute %emlogl=%logl
   @MSRegmstep(nodop,nodobeta,dosigma) start end
   set l11 start end = 0.0
   set l22 start end = 0.0
   set w11 start end = 0.0
   set w22 start end = 0.0
   compute tvemlogl=0.0
   do time=start,end
      compute p=%MSPMat(time)
      compute thisEntry=%zeros(nstates,nstates)
      do k=1,MSEMSize
         compute thisEntry(MSEMLagRegime(k,1),MSEMLagRegime(k,2))+=MSEMpt_sm(time)(k)
         compute tvemlogl+=log(p(MSEMLagRegime(k,1),MSEMLagRegime(k,2)))*MSEMpt_sm(time)(k)
      end do k
      compute w11(time)=p(1,1)*(1-p(1,1))*(thisEntry(1,1)+thisEntry(2,1))
      compute w22(time)=p(1,2)*(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2))
      compute l11(time)=(thisEntry(1,1)- p(1,1)*(thisEntry(1,1)+thisEntry(2,1)))/w11(time)
      compute l22(time)=(thisEntry(2,2)-(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2)))/w22(time)
   end do time
   * Update the coefficients
   linreg(noprint,weight=w11,equation=p1eq) l11 start end
   compute v1=v1+%beta
   linreg(noprint,weight=w22,equation=p2eq) l22 start end
   compute v2=v2+%beta
   do time=start,end
      do k=1,MSEMSize
      end do k
   end do time
   * Check for convergence
   compute testparms=v1~~v2
   compute %cvcrit=%testdiff(baseparms,testparms)
   if %cvcrit<cvcrit
      break
   compute baseparms=testparms
   disp "Iteration" emits "Log Likelihood" %emlogl %cvcrit
end do emits
end MSTVPEMEstimate
compute v1=log(.7/.3)
compute v2=log(.95/.05)
@MSTVPEMEstimate(cvcrit=.0001) gstart gend
equation p1eq *
# constant logvix{1}
equation p2eq *
dim p1mean(%eqnsize(p1eq)) p2mean(%eqnsize(p2eq))
do i=1,%eqnsize(p1eq)
   sstats(mean) gstart gend %eqnxvector(p1eq,t)(i)>>p1mean(i)
do i=1,%eqnsize(p2eq)
   sstats(mean) gstart gend %eqnxvector(p2eq,t)(i)>>p2mean(i)
compute v1=v1~~0.0
compute v2=v2~~0.0
@MSTVPEMEstimate(cvcrit=.0001,iters=50) gstart gend
* Polish estimates using BHHH
frml logltvtp = p=%MSPMat(t),log(%MSRegProb(t))
@MSFilterInit
maximize(parmset=tv+common,start=(pstar=TVPInit()),method=bhhh,iters=10) logltvtp gstart gend
If I want to estimate the Filardo-type TVTP-MS model with @MSRegression, what modifications should I make?
(That is, how to modify the code of the example to make the transition probabilities vary with some exogenous variables? )
Best regards,
Samson
Re: Estimate the TVTP-MS model with MSRegression
Posted: Wed Aug 01, 2012 12:53 pm
The last estimates on that have transition probabilities that vary with logvix{1}. The first set uses the TV setup to estimate a fixed transition model.
Posted: Wed Aug 01, 2012 9:41 pm
by samson
Dear Tom:
You mean that the code above actually estimates a TVTP-MS model, right?
But something weird occurred when I relicated Filardo(1994) with the @msregression.
The codes and results from the @msregression are :
    Variable                         Coeff         Std Error       T-Stat       Signif
1.  V1(1)                             28.045926   162464.058048  1.72628e-004  0.99986226
2.  V1(2)                         -14390.350151 26757918.441531 -5.37798e-004  0.99957090
3.  V2(1)                             31.253470        0.000000       0.00000  0.00000000
4.  V2(2)                             29.059143        0.000000       0.00000  0.00000000
5.  GAMMAS(1)                          0.186422        0.023092       8.07286  0.00000000
6.  GAMMAS(2)                          0.150159        0.034618       4.33760  0.00001440
7.  GAMMAS(3)                         -0.008068        0.035597      -0.22665  0.82069296
8.  GAMMAS(4)                         -0.050465        0.031893      -1.58231  0.11357968
9.  BETAS(1)(1)                  -793779.512908        0.000000       0.00000  0.00000000
10. BETAS(2)(1)                        0.168200        0.025593       6.57216  0.00000000
11. SIGSQ                              0.417337        0.000000       0.00000  0.00000000
compute gstart=1948:6,gend=1992:8
@MSRegression(states=2,NFIX=4, switch = c) g
# g{1} g{2} g{3} g{4} constant
@MSRegInitial gstart gend
@MSFilterSetup(em)
nonlin(parmset=common) gammas betas sigsq
dec vector   v1     v2
equation p1eq *
# constant
equation p2eq *
# constant
type rect %MSPmat
type int time
local integer i j
local rect pexpand
local real z
local rect p
dim p(1,2)
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
dim p(1,2)
do emits=1,iters
   compute TVPInit()
   do time=start,end
      do k=1,MSEMSize
      end do k
   end do time
   compute v1=v1+%beta
   compute v2=v2+%beta
   do time=start,end
      do k=1,MSEMSize
      end do k
   end do time
   if %cvcrit<cvcrit
      break
  * disp "Iteration" emits "Log Likelihood" %emlogl %cvcrit
end do emits
end MSTVPEMEstimate
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
compute v1=v1~~0.0
compute v2=v2~~0.0
frml logltvtp = f=%MSRegFVec(t),tvtp=%MSProb(t,f),log(tvtp)
@MSFilterInit
maximize(parmset=tv+common,start=(pstar=TVPInit()),method=bhhh,iters=100) logltvtp gstart gend
It seems that it does not converge at the end of the iterations.
In addition, at the last part of the code I use
rather than
because RATS returns: ## SX11. Identifier %MSREGPROB is Not Recognizable.
How to solve this problem?
Best regards,
Samson
Posted: Sun Aug 05, 2012 7:35 pm
by samson
I fix the weird problem described at last post. (I forgot sourcing the msregression.src.)
But the estimates of replication of Filardo(1994) are somehow different between the @msvar and the @msreg.
The codes of @msreg are:
@MSFilterSetup(em)
dec vector   v1     v2
equation p1eq *
# constant
equation p2eq *
# constant
type rect %MSPmat
type int time
local integer i j
local rect pexpand
local real z
local rect p
dim p(1,2)
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
dim p(1,2)
do emits=1,iters
   compute TVPInit()
   do time=start,end
      do k=1,MSEMSize
      end do k
   end do time
   compute v1=v1+%beta
   compute v2=v2+%beta
   do time=start,end
      do k=1,MSEMSize
      end do k
   end do time
   if %cvcrit<cvcrit
      break
end do emits
end MSTVPEMEstimate
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
compute v1=v1~~0.0
compute v2=v2~~0.0
@MSFilterInit
And the results from both procedures are:
MSVAR
MAXIMIZE - Estimation by BHHH
Convergence in    36 Iterations. Final criterion was  0.0000076 <=  0.0000100
Monthly Data From 1948:06 To 1992:08
Usable Observations                       531
Function Value                      -595.8451
1.  V1(1)                         1.330180283  0.453513451      2.93306  0.00335643
2.  V1(2)                        -1.191657247  0.711571594     -1.67468  0.09399634
3.  V2(1)                         4.285992396  0.991396606      4.32319  0.00001538
4.  V2(2)                         1.649574337  0.716078802      2.30362  0.02124391
5.  MU(1)(1)                     -0.881223949  0.121836490     -7.23284  0.00000000
6.  MU(2)(1)                      0.472023399  0.060484834      7.80400  0.00000000
7.  PHI(1)(1,1)                   0.210997467  0.037889959      5.56869  0.00000003
8.  PHI(2)(1,1)                   0.072442917  0.054571339      1.32749  0.18434658
9.  PHI(3)(1,1)                   0.103731081  0.050537956      2.05254  0.04011740
10. PHI(4)(1,1)                   0.102676704  0.048535910      2.11548  0.03438913
11. SIGMA(1,1)                    0.472888920  0.027754232     17.03844  0.00000000
MSREG
Convergence in    33 Iterations. Final criterion was  0.0000078 <=  0.0000100
Function Value                      -598.3348
1.  V1(1)                         0.325691305  0.578086749      0.56340  0.57316580
2.  V1(2)                        -2.819968505  1.338370453     -2.10702  0.03511616
3.  V2(1)                         2.297306819  0.872960135      2.63163  0.00849767
4.  V2(2)                         2.309537673  1.014590928      2.27632  0.02282663
5.  GAMMAS(1)                     0.237389211  0.032336567      7.34120  0.00000000
6.  GAMMAS(2)                    -0.015598865  0.043780601     -0.35630  0.72161869
7.  GAMMAS(3)                     0.032617005  0.045796841      0.71221  0.47633425
8.  GAMMAS(4)                     0.032454099  0.038069459      0.85250  0.39393832
9.  BETAS(1)(1)                  -0.367262722  0.076315622     -4.81242  0.00000149
10. BETAS(2)(1)                   0.432266265  0.043772752      9.87524  0.00000000
11. SIGSQ                         0.417336613  0.000000000      0.00000  0.00000000
The standard error and the T-statistic of the variance from @msreg are both zero. (That's really strange.)
Is there something wrong in the codes?
I'd really appreciate your help~~
Best regards,
Samson
