The construction of panel unit root
Posted: Tue Jul 10, 2012 2:23 am
Always thank you so much for your kind reply.
After rearranging the data, right now I am doing panel unit root test in terms of Constant and Constant+Trend.
Then I got the results:
My questions are:
1. How to do panel unit root test in terms of Constant and Constant+Trend? Note:Options in @pancoit do not work here.
2. How to get the panel unit root for P and N also in terms of Constant and Constant+Trend?
Thank you very much for your precious time and attention.
Best Regards
guo
OPEN DATA "D:\Electro New\panel rearragment 2012-7-8.xlsx"
CALENDAR(M) 2003:2
DATA(FORMAT=XLSX,ORG=COLUMNS,right=100) 2003:02 2012:04
pform x
# individual_1 to individual_96
calendar(m,panel=2012:3) 2003:2
all 96//2012:3
pform(repeat) p_new
# p
pform(repeat) n_new
# n
* panel unit root test
* Supplementary card:
* If you list just one variable, it will do a raw panel unit root test
@pancoint X
# X
@pancoint P
# P
@pancoint N
# N
RESULTS:
-raw panel unit root test results-
Levin-Lin rho-stat = -371.05071
Levin-Lin t-rho-stat = -143.86232
Levin-Lin ADF-stat = -72.30250
IPS ADF-stat = -97.65569
(using large sample adjustment values)
Nsecs = 96 , Tperiods = (unbalanced) , no. regressors = 0
All reported values are distributed N(0,1)
under null of unit root or no cointegration
Panel stats are weighted by long run variances
(see OBES reference for details)
Currently computing panel statistics. Please wait.
The Error Occurred At Location 2830, Line 236 of PANCOINT
Best Regards
guo
