Open files using loop
Posted: Wed Jun 20, 2012 2:44 pm
by kwangsooKo
Dear Sir,
I am trying to create a do loop for opennig xlsx files.
I have three files that are composed of same series with different lengths, and each file’s name are a number 1, 2, and 3. I made programs but Something seems wrong.
Also I am trying to export residuals series as xls files named n.
I can click view/series windows/name of residuals/export .But I don’t know how can I export files in loop.
The following is my attempt:
do n=1,3
OPEN DATA "C:\Documents and Settings\n.xlsx"
DATA(FORMAT=XLSX,ORG=COLUMNS)
LINREG RT / U
# IF OI RT{1}
*export residuals series as xls files named n
end do n
Thank you very much for your time and help.
Regards
Re: Open files using loop
Posted: Wed Jun 20, 2012 2:56 pm
See section 1.6 of the (RATS v8 ) User's Guide. The example there does
declare string fname
compute fname=%l(i)+".XLS"
open copy &fname
copy(format=xls,org=col,dates) / i
to open a file with a constructed name.
Posted: Thu Jun 21, 2012 4:26 am
by kwangsooKo
Thanks for your helping.
Best Regards
Posted: Fri Apr 25, 2014 4:13 am
by jonasdovern
I am working with similar code.
When I run the code ...
do w=1,nwindows
do i=1,15
comp [string] fname = "Res_new_"+%string(w)+"_"+%string(i)
open data &fname
data(format=xls,org=row) /
comp [string] fname = "dRes_new_"+%string(w)+"_"+%string(i)
open data &fname
close data
end do w
... RATS asks me to confirm each Excel file before it is opened (which in other situations with RATS I only know from when an Excel file is still open in Excel). With nwindows being equal to 5 this does not work out in a reasonable period of time. I guess there should be a way to suppress the appearance of these "confirmation windows" during the loop. Can you help me out on this?
Posted: Fri Apr 25, 2014 6:59 am
If you don't have a path on the file name, it will check in the current working directory; if the file isn't found there, it pops up the dialog. The working directory tends to follow the program that you opened, so if you have a complex directory tree you might need to put full paths in on the data files.
Posted: Sun Apr 27, 2014 5:43 am
by jonasdovern
This isn't the problem. I tried both: Saving the Excel files into the current working directory (because I wasn't sure whether the &fname-construction could handle full paths) and saving it to a different folder and specifying the full paths in fname (because I thought that this should be possible).
Is there an issue with the number of series stored in one of the Excel files? Because it does work with a simple example based on a couple of Excel files that have only one series.
I am attaching the first two files to be read in the loop. The following is the loop that I use:
do w=1,nwindows
do i=1,15
comp fname = "Res_new_"+%string(w)+"_"+%string(i)
open data &fname
comp fname = "dRes_new_"+%string(w)+"_"+%string(i)
open data &fname
close data
do c=1,nc
do v=1,%rows(gvarfcts(c))
do f=1,fsteps
set gvarfcts(c)(v)(f) / = gvarfcts(c)(v)(f)(t)+%s("f1_"+%string(c)+"_"+%string(v)+"_"+%string(f))(t)/(15.*nwindows)
set dgvarfcts(c)(v)(f) / = dgvarfcts(c)(v)(f)(t)+%s("df1_"+%string(c)+"_"+%string(v)+"_"+%string(f))(t)/(15.*nwindows)
set mgvarfcts(i,w)(c)(v)(f) / = %s("f1_"+%string(c)+"_"+%string(v)+"_"+%string(f))(t)
set mdgvarfcts(i,w)(c)(v)(f) / = %s("f1_"+%string(c)+"_"+%string(v)+"_"+%string(f))(t)
end do f
end do v
end do c
end do w
Posted: Sun Apr 27, 2014 8:38 am
You're missing the extension:
comp fname = "Res_new_"+%string(w)+"_"+%string(i)+".xls"
Posted: Mon Apr 28, 2014 3:10 am
by jonasdovern
My god! Yes. Sorry for asking.
