SSVAR Proc: Gibbs estimation of VAR with steady state prior
tclark
Unread post by tclark »
Drawing on code from Tom Doan, this procedure uses Gibbs sampling to estimate (and obtain forecasts from) a VAR with an informative prior on the steady state, using the method of Villani (reference given in procedure file). Be forewarned that there are various aspects of the procedure that could be made more user friendly or coded more efficiently.
* PROCEDURE:  SSVAR.src
* syntax: @SSVAR(options) y d stpt endpt prenobs lags prelags ndraws burndraws meanfirstlag Pipriorprec shrinkage Psipriormean Psistdev fcper &
*                   PiRes PsiRes SigmaRes ForecastRes
*           Written by Todd Clark of the Federal Reserve Bank of Kansas City, drawing on code by Tom Doan
* PURPOSE:  Using Gibbs sampling as in Villani, Mattias (2006), ``Inference in Vector Autoregressive Models with an Informative Prior
*            on the Steady State,'' Sveriges Riksbank Research Paper No.\ 19, forthcoming in the Journal of Applied Econometrics.
*            Program generates posterior estimates (including forecasts, if the user chooses)
*            The model/estimator is similar to the normal-diffuse of Kadiyala and Karlsson (1997), "Numerical Methods for Estimation and
*            Inference in Bayesian VAR Models," Journal of Applied Econometrics, pp 99-132, extended to allow a prior on the steady state.
*            The model takes the form
*            Pi(L)*[y(t)-Psi*d(t)] = eps(t),     eps(t)~iid N(0,Sigma).
*            where:  Pi(L)=I-Pi2*L-...-Pik*L^k, and the prior on Sigma is diffuse.
* NOTES:  (1) priors for slope coefs of VAR, Pi(L), are handled with modified Litterman approach, without options
*         (2) priors for the steady state coefs Psi, are handled as in Villani
* INPUT:    y                  vector of series of observed endogenous variables
*           d                  vector of series of exogenous (deterministic) variables
*           stpt               starting point of estimation (meaning observations back to stpt-lags) serve as initial values
*           endpt              end point of estimation sample
*           prenobs            number of observations in pre-sample to use for setting priors.  If the actual number available
*                                falls short of prenobs, the priors (in this case, just the prior variance on Pi) are pulled
*                                from values that need to be defined from outside the procedure.
*           lags               Lag length of the VAR.
*           prelags            lag of AR model used in pre-sample estimation that pins down some priors
*           ndraws             number of total posterior draws
*           burndraws          number of burnin draws
*           MeanFirstLag       Prior mean vector for first own lag (Pi). Only used for the Litterman prior.
*           Pipriorprec        If there are enough data in the training sample, the prior precision is estimated based on the pre-sample;
*                                  if there isn't enough data, the prior precision needs to be given (input) in Pipriorprec
*           Shrinkage          Hyperparameters in prior.  Smaller values produces priors which are more concentrated around zero.
*                              - Shrinkage(1): Baseline tightness parameter.
*                              - Shrinkage(2): Own/others shrinkage
*                              - Shrinkage(3): Lag length shrinkage parameter.
*           Psipriormean       prior mean for Psi (vector)
*           Psistdev           prior standard deviation for Psi (vector)
*           fcper              number of periods ahead to forecast (set to 0 to skip forecasting)
* OUTPUT:   PiRes              vector of post-burn draws of Pi
*           PsiRes             vector of post-burn draws of Psi
*           SigmaRes           vector of post-burn draws of Sigma
*           ForecastRes        rect array of time series of forecasts, covering post-burn draws and num of variables
*   -Options:
*     printinit/[noprintinit] : display initial priors/values (default is noprint)
*     printmean/[noprintmean] : display posterior means and standard deviations (default is noprint)
* FIRST:    2008-05-09
*********************************** declarations
procedure SSVAR y d stpt endpt prenobs lags prelags ndraws burndraws meanfirstlag Pipriorprec shrinkage Psipriormean Psistdev $
  fcper PiRes PsiRes SigmaRes ForecastRes
type vec[ser] y d
type int stpt endpt prenobs lags prelags ndraws burndraws fcper
type vec meanfirstlag shrinkage Psipriormean Psistdev
type vec[rec] *PiRes *PsiRes
type vec[symm] *SigmaRes
type rec[ser] *ForecastRes
type symm *Pipriorprec
** start here
option switch prinit 0
option switch prmean 0
* note that what this local stuff is used for becomes clearer below
local int nvar ndet draws_burn ncoef i j l draws row col nobs rawstpt ystpt availprenobs
local index dvarlist
local vec[ser] ydtr residuals dminus forecasts
local rec[ser] tempresiduals
local vec univar ux_psi ux Pihat_ols Pimean Pidraw Pipriormean Psidraw Psimean
local symm psipriorv invomegaprior hx Omegamean wparm hb Sigma invSigma dd xxxols
local rec minnmean minnprec uprime Pidraw_mat Psidraw_mat fx fx_Omega meanmat sdmat ydcov
local rec pimat
local model varmodel ssmodel
*********************************** dimensioning
***** key dimensions
comp nvar = %rows(y)
comp ndet = %rows(d)
comp ncoef = nvar*lags              ;* number of slope coefficients in each equation
comp draws_burn = ndraws - burndraws
comp nobs = endpt-stpt+1
***** stuff stored, for all post-burn draws
dim PiRes(draws_burn) PsiRes(draws_burn) SigmaRes(draws_burn) ForecastRes(draws_burn,nvar)
***** stuff for Pi computations
dim univar(nvar)  ;* for storing univariate st devs used in setting Pi prior standard deviations
dim ux(nvar*ncoef) ;* used for drawing innovations
dim Pidraw(ncoef*nvar) ;* vector for drawing Pi
***** stuff for Pi prior (Litterman mean and variance)
comp minnmean = %zeros(ncoef,nvar)
comp minnprec = %zeros(ncoef,nvar) ;* precision^2 = inverse of the variance
***** stuff for Psi computations
dim ux_psi(nvar*ndet) ydtr(nvar) residuals(nvar) dminus(ndet)
comp psipriorv = %diag(Psistdev.*Psistdev)
comp invomegaprior = inv(psipriorv)
comp uprime = %zeros(nvar*ndet,(lags+1)*nvar*ndet)
comp %psubmat(uprime,1,1,%identity(nvar*ndet))
comp pimat = %zeros(nvar,nvar)
*********************************** setting priors (Minneapolis prior on slope coefs Pi) from pre-sample estimates
*********************************** Note:  precision is only set if the available sample size (availprenobs)
*********************************** is at least as great as specified by the inputs (prenobs+prelags).
*********************************** If the sample isn't big enough, precision is left at the value provided in the
*********************************** procedure call.
comp rawstpt = 0
do i = 1,nvar
 inquire(series=y(i)) ystpt *
 comp rawstpt = %imax(rawstpt,ystpt)
comp availprenobs = stpt-1 - rawstpt + 1
if availprenobs>=(prenobs+prelags)
  do i = 1,nvar
    linreg(noprint) y(i) stpt-prenobs stpt-1
    # constant y(i){1 to prelags}
    comp univar(i)=sqrt(%seesq)  ;* %rss/%nobs
***** setting mean and precision
do i=1,nvar
 do j=1,nvar
  do l=1,lags
   comp minnmean((j-1)*lags+l,i)=(i==j.and.l==1)*MeanFirstLag(i)
    comp minnprec((j-1)*lags+l,i)=univar(j)/univar(i)*%if(i==j,float(l)**shrinkage(3)/shrinkage(1),float(l)**shrinkage(3)/(shrinkage(2)*shrinkage(1)))
  end do l
comp Pipriormean=%vec(minnmean)         ;* prior mean, in vector form
  ewise minnprec(i,j)=minnprec(i,j)**2
  comp Pipriorprec=%diag(%vec(minnprec))  ;* inverse of prior variance matrix
************************************ setting initial values needed in MCMC
comp Psidraw = Psipriormean + %ranmvnormal(%decomp(psipriorv))   ;* initial draw of Psi
cmom(center) stpt endpt
# y
comp sigma=%ranwisharti(%decomp(inv(.9*%cmom)),nobs)    ;* initial draw of Sigma, using .9*var-cov of y as scale matrix
if prinit==1
  dis ''
  dis 'initial Psi = ' Psidraw
  dis ''
  dis 'initial Sigma = ' Sigma
*********************************** more set up for MCMC
smpl stpt endpt  ;* sample for estimation
***** set up D matrix for steady state prior, outside loop since it is just based on fixed data
comp dvarlist = %rlempty()
enter(varying) dvarlist
# dvarlist d
do j = 1,ndet
  set dminus(j) stpt-lags endpt = -1.*d(j){0}
do i = 1,lags
 do j = 1,ndet
  # dvarlist dminus(j){i}
cmom(matrix=dd,nocenter)
# dvarlist
***** model in just deterministic variables, used in loop to demean y variables
system(model=ssmodel)
variables y
det d
** now need to assign coefs and run through filter to define demeaned y (ydtr) for first draw
comp Psidraw_mat = tr(%vectorect(Psidraw,nvar))
comp %modelsetcoeffs(ssmodel,Psidraw_mat)
steps(model=ssmodel,results=tempresiduals) * (endpt-(stpt-lags)+1) stpt-lags
do i = 1,nvar
  set ydtr(i) stpt-lags endpt = tempresiduals(2,i)
***** demeaned VAR used in loop, in demeaned y variables
system(model=varmodel)
variables ydtr
lags 1 to lags
kfset xxxols
** note:  because using the option (model=varmodel) with estimate() causes MacRATS v7 to crash, I
**        don't use it.  As a result, to be sure the estimate() is estimating the right model, it has to
**        be the case that, in the above defs, varmodel is defined after ssmodel
*********************************** MCMC
do draws=1,ndraws
 ********************** STEP 1:  drawing Pi (VAR slope coefs)
 ****** forming OLS estimates and moments for ydtr = y - Psi*d
 estimate(noprint) ;* ,  note:  including the model option causes a crash in v7 of RATS
 comp Pihat_ols=%vec(%modelgetcoeffs(varmodel))
 ****** drawing slope coefficients, and reassigning them to model
 comp invSigma = inv(sigma)
 comp hb=%kroneker(invsigma,inv(xxxols))
 comp hx=inv(hb+Pipriorprec)
 comp Pimean=hx*(Pipriorprec*Pipriormean+hb*Pihat_ols)
 comp fx=%decomp(hx)
 comp Pidraw = Pimean+fx*(ux=%ran(1.0))
 comp Pidraw_mat = %vectorect(Pidraw,ncoef)
 comp %modelsetcoeffs(varmodel,Pidraw_mat)
 ********************** STEP 2:  drawing Psi (steady state coefficients)
 ** first redefine ydtr to be raw data
 do i = 1,nvar
  set ydtr(i) stpt-lags endpt = y(i){0}
 ** forming Y series
 steps(model=varmodel,results=tempresiduals)
 do i = 1,nvar
   set residuals(i) = tempresiduals(2,i)
 cmom(nocenter)
 # residuals dvarlist
 comp ydcov = %xsubmat(%cmom,1,nvar,nvar+1,%cols(%cmom))
 ** setting up U matrix
 do i = 1,lags
  ewise pimat(row,col) = Pidraw_mat((col-1)*lags+i,row)
  comp %psubmat(uprime,1,(ndet*nvar)*i+1,%kroneker(%identity(ndet),tr(pimat)))
 ** posterior computations
 comp omegamean = inv(%mqform(%kroneker(dd,invsigma),tr(uprime)) + invomegaprior)
 comp Psimean = omegamean*(uprime*%vec(invsigma*ydcov) + invomegaprior*Psipriormean)
 comp fx_omega = %decomp(omegamean)
 comp Psidraw=Psimean+fx_omega*(ux_psi=%ran(1.0))
 ********** STEP 3: Draw Sigma
 **********  (first filter data to get residuals:  first subtract out means, and then run through demeaned VAR,
 **********    then compute residual var-cov, then take Sigma draw)
 do i = 1,nvar
 steps(model=varmodel,results=tempresiduals) ;* filtering demeaned y's to get residuals
 do i = 1,nvar
 cmom(matrix=wparm)
 # residuals
 comp sigma=%ranwisharti(%decomp(inv(wparm)),nobs)
 ******* storage of MCMC draws, and construction of foreasts for storage
 if draws>burndraws
   *** storing everything but forecasts
   comp PiRes(draws-burndraws) = Pidraw_mat
   comp PsiRes(draws-burndraws) = Psidraw
   comp SigmaRes(draws-burndraws) = Sigma
   *** construction and storing forecasts:  (1) generate forecasts of (y - steady states), and (2) add back in steady state
   if fcper>0
     simulate(model=varmodel,results=forecasts) * fcper endpt+1 sigma
     do i = 1,nvar
      set forecastRes(draws-burndraws,i) endpt+1 endpt+fcper = forecasts(i){0} + %dot(%eqncoeffs(%modeleqn(ssmodel,i)),%eqnxvector(%modeleqn(ssmodel,i),t))
end do draws
if prmean==1
dis ''
comp meanmat = %zeros(%rows(PsiRes(1)),%cols(PsiRes(1)))
comp sdmat = %zeros(%rows(PsiRes(1)),%cols(PsiRes(1)))
do i = 1,draws_burn
 comp meanmat = meanmat + PsiRes(i)
 comp sdmat = sdmat + PsiRes(i).*PsiRes(i)
comp meanmat = meanmat*(1./draws_burn)
comp sdmat = %sqrt(sdmat*(1./draws_burn) - meanmat.*meanmat)
dis 'Psi mean ='
dis ###.### meanmat
dis 'Psi st dev ='
dis ###.### sdmat
** MCMC mean and standard deviation for Pi
comp meanmat = %zeros(%rows(PiRes(1)),%cols(PiRes(1)))
comp sdmat = %zeros(%rows(PiRes(1)),%cols(PiRes(1)))
do i = 1,draws_burn
 comp meanmat = meanmat + PiRes(i)
 comp sdmat = sdmat + PiRes(i).*PiRes(i)
dis 'Pi mean ='
dis ###.### meanmat
dis 'Pi st dev ='
dis ###.### sdmat
** MCMC mean and standard deviation for Sigma
comp meanmat = %zeros(%rows(SigmaRes(1)),%cols(SigmaRes(1)))
comp sdmat = %zeros(%rows(SigmaRes(1)),%cols(SigmaRes(1)))
do i = 1,draws_burn
 comp meanmat = meanmat + SigmaRes(i)
 comp sdmat = sdmat + SigmaRes(i).*SigmaRes(i)
dis 'Sigma mean ='
dis ###.### meanmat
dis 'Sigma st dev ='
dis ###.### sdmat
Todd Clark
Economic Research Dept.
