Stochastic Volatility Model
Posted: Wed Feb 22, 2012 2:42 am
Dear Sir,
I am trying to utilize the "Replication file for Harvey, Ruiz and Shephard(1994), "Multivariate
Stochastic Variance Models", Review of Economic Studies, vol 61, no." I tested by inserting my numbers for a 3-variable model into the program u provided. I changed the dimensions to (3,3) and wonder wther it is correct?
I have some questions which I would like to clarify too. These questions were made in red. Many thanks for your kind replies.
* meanx2=mean of log chi-square,varx2=variance of log chi-square
compute meanx2=%digamma(0.5)-log(0.5)
compute varx2 =%trigamma(0.5)
dec vect[series] w(3)
set w(1) = log(svhat1)-meanx2
set w(2) = log(svhat2)-meanx2
set w(3) = log(svhat3)-meanx2
set w(4) = log(svhat4)-meanx2
The paper states that meanx2 = -1.27. The original program was written as w(1) = log(demean**2)-meanx2? since meanx2 is negative, is it subtracted to make make log e^2 positive?
in your program, is demean the standard deviation for dlogp?
I created a DLM model (not shown here), retrieving vhat and svhat . I subsequently used this svhat in place of demean**2 as seen above. However, there is no convergence. does it mean i am wrong and should use vhat instead?
By deriving the demean by:
diff(center) vhat1 / demean[/color][/color]
diff(center) vhat2 / demean[/color][/color]
diff(center) vhat3 / demean[/color][/color]
diff(center) vhat4 / demean[/color][/color][/color][/color]
dec packed rhosd(2,2) sigetaf(3,3)
dec symm sv(3,3)
What is the purpose of rhosd(2,2) and sigetaf(3,3)? does rhosd have to be one less than the size of sigetaf?
* %rhosw combines the packed lower triangular "rho" matrix with the
* known variances of the components to give the full covariance matrix.
* The sigma eta matrix is easier to estimate in square root form so it
* is also a packed lower triangle. This also makes the estimation
* process more similar to the factor method later.
function %rhosw
type symm %rhosw
local integer i j
dim %rhosw(3,3)
ewise %rhosw(i,j)=%if(i==j,varx2,varx2*rhosd(i-1,j))
function %ltouterxxF
type symm %ltouterxxF
local rect lt(3,3)
local integer i j
ewise lt(i,j)=%if(i>=j,sigetaf(i,j),0.0)
compute %ltouterxxF=lt*tr(lt)
* sigmaeps backs out the covariance matrix of epsilon from the estimate
* for eta
function %sigmaeps
type symm %sigmaeps
local integer i j n
local real rhowork rho factor
local parmset rootf
dim %sigmaeps(3,3)
do i=1,3
compute %sigmaeps(i,i)=%pi**2/2.0
do j=1,i-1
nonlin(parmset=rootf) rho
compute rho=rhosd(i-1,j)
find(noprint,parmset=rootf) root rhosd(i-1,j)-rhowork
compute rhowork=0.0
compute factor=2.0*rho**2
do n=1,100
compute rhowork=rhowork+factor/n
compute factor=factor*n/(n+.5)*rho**2
end do n
compute rhowork=rhowork*2.0/%pi**2
end find
compute %sigmaeps(i,j)=rho*%pi**2/2.0
nonlin rhosd sigetaf
compute [rect] c=%identity(3)
compute rhosd=%const(0.0)
compute sigetaf=%sqrt(%diag(||.001,.001,.001||))
why are these numbers (||4.2,16.1,3.4,19.4||)) chosen in your program?
dlm(y=%xt(w,t),c=c,startup=%(sv=%rhosw(),sw=.001*%ltouterxxF()),sw=sw,sv=sv,$
presample=diffuse,condition=1,method=bfgs,iters=100) 2 *
* Get the covariance matrix for epsilon
compute sigmaeps=%sigmaeps()
* Show the correlation matrices for epsilon and eta
disp %cvtocorr(sigmaeps)
disp %cvtocorr(sw)
* Table 4 analysis. Because the estimated sigmaeta is quite a bit
* different, these results are as well. The eigenvectors shown in this
* table are actually scaled by the square roots of eigenvalues as is
* done in table 5, so there is no need for a separate table.
eigen(scale) sw eigval eigvect
report(action=define)
report(atrow=1,atcol=1) "(a)" "Eigenvalues" eigval
report(atrow=2,atcol=2) "Eigenvectors" eigvect
report(atrow=6,atcol=2) "Percentage of Variance" eigval/%sum(eigval)
eigen(scale) %cvtocorr(sw) eigval eigvect
report(atrow=8,atcol=1) "(b)" "Eigenvalues" eigval
report(atrow=9,atcol=2) "Eigenvectors" eigvect
report(atrow=13,atcol=2) "Percentage of Variance" eigval/%sum(eigval)
report(action=show)
* Two factor model. This is parameterized somewhat differently than is
* shown in the text. It keeps four states, but with a deficient rank
* covariance matrix. This makes it a restriction on the original four
* state model.
dec rect theta(3,2)
I wonder whether changing to theta(3,2) is correct?
nonlin rhosd theta theta(1,2)=0.0
dlm(y=%xt(w,t),c=c,startup=%(sv=%rhosw(),sw=theta*tr(theta)),sv=sv,sw=sw,$
presample=diffuse,condition=1,type=smooth,$
pmethod=simplex,piter=10,method=bfgs) 2 * xstates
* Rotation to make 1st loading on yen=0
compute lambda1=%atan(-theta(2,1)/theta(2,2))
compute rotate1=||cos(lambda1),-sin(lambda1)|sin(lambda1),cos(lambda1)||
compute loading1=theta*rotate1
* Rotation to make 2nd loading on DM=0
compute lambda2=%atan(theta(1,1)/theta(2,1))
compute rotate2=||cos(lambda2),-sin(lambda2)|sin(lambda2),cos(lambda2)||
compute loading2=theta*rotate2
* Generate Table 6
report(atrow=1,atcol=2,tocol=3,span) "Rotation 1"
report(atrow=1,atcol=4,tocol=5,span) "Rotation 2"
report(atrow=2,atcol=1,fillby=cols) "Pound/Dollar" "DM/Dollar" "Yen/Dollar" "SF/Dollar"
report(atrow=2,atcol=2) loading1
report(atrow=2,atcol=4) loading2
report(action=format,picture="*.###")
report(action=show)
* Invert the loadings to create the rotated factors
compute trans2=%ginv(loading2)
set factor21 2 * = %dot(%xrow(trans2,1),xstates(t))
set factor22 2 * = %dot(%xrow(trans2,2),xstates(t))
set dm1 2 * = factor21*loading2(2,1)
set yen2 2 * = factor22*loading2(3,2)
* Estimate the smoothed component from the univariate RW model for DM
nonlin swx
boxjenk(ar=1,ma=1,constant,noprint) w(2)
compute swx=.0161
dlm(y=w(2),c=1.0,sw=swx,sv=varx2,a=1.0,exact,$
method=bfgs,type=smooth,noprint) 2 * states
* The parameterization used for the factor model in the text generates
* factors which give roughly the correct level for the first two
* currencies. The other two require mean shifts, which is why there's a
* gap between the curves in 3(b). Since that decision was arbitrary (the
* two mean shifts could have been associated with any two currencies),
* we graph the standard deviations adjusted so the means match up (in
* log scale) with the means from the corresponding univariate process.
set dmuni 2 * = states(t)(1)
sstats(mean) 2 * dmuni-dm1>>adjust
set dm1 = exp(.5*(dm1+adjust))
set dmuni = exp(.5*dmuni)
graph(header="Figure 3(a) Smooth estimates of standard deviations for the first common trend") 2
# dm1
# dmuni
* Same for the yen
nonlin swx
boxjenk(ar=1,ma=1,constant,noprint) w(3)
compute swx=.0034
dlm(y=w(3),sw=swx,sv=varx2,c=1.0,a=1.0,exact,$
set yenuni 2 * = states(t)(1)
sstats(mean) 2 * yenuni-yen2>>adjust
set yen2 = exp(.5*(yen2+adjust))
set yenuni = exp(.5*yenuni)
graph(header="Figure 3(b) Smooth estimates of standard deviations for the second common trend") 2
# yen2
# yenuni
* Estimation allowing for t-distribution. Add a diagonal adjustment
* matrix to the sv matrix. Since the elements of that are the variances
* of the log kappa's the adjustment has to be constrained to be
* non-negative.
dec vect zetad(3)
what is the purpose of zetad?
nonlin rhosd sigetaf zetad zetad>=0.0
dlm(y=%xt(w,t),c=c,startup=%(sv=%rhosw()+%diag(zetad),sw=.001*%ltouterxxF()),$
sw=sw,sv=sv,presample=diffuse,condition=1,$
pmethod=simplex,piter=0,method=bfgs,iters=100) 2 *
How do i get the covariance i.e. off -digaonal elements?
dec symm sv(3,3)
function %rhosw
type symm %rhosw
local integer i j
dim %rhosw(3,3)
local rect lt(3,3)
local integer i j
* for eta
function %sigmaeps
type symm %sigmaeps
local integer i j n
local parmset rootf
dim %sigmaeps(3,3)
do i=1,3
do j=1,i-1
compute rhowork=0.0
do n=1,100
end do n
end find
disp %cvtocorr(sw)
report(action=show)
* state model.
dec rect theta(3,2)
* Generate Table 6
report(action=show)
nonlin swx
compute swx=.0161
# dm1
# dmuni
* Same for the yen
nonlin swx
compute swx=.0034
# yen2
# yenuni
* non-negative.
dec vect zetad(3)
