FMOLS Wald Test
Posted: Mon Jan 14, 2008 11:03 am
by paldejong
Dear RATS Users,
First and foremost, Happy New Year to all of you!
For my latest revision of research, I am using the FMOLS procedure for cointegrated panels by Pedroni (Pedroni, Peter (2000) "Fully Modified OLS for
Heterogeneous Cointegrated Panels," Advances in Econometrics, Vol. 15, 93-130) to test for cointegration before and after a significant economic event. A reviewer suggested that I should not just rely on the point parameters (one before and after the event) but should report a statistic of potential difference between the parameters based on the Wald test. I am not quite sure on how to implement this. I could use your help.
Thank you,
Pieter de Jong
Re: FMOLS Wald Test
Posted: Tue May 15, 2012 11:48 am
I assume from the description that you want to test for a difference in the cointegrating vector before and after. If you do a sample split, the estimators before and after should be uncorrelated, so the variance of the difference would be the sum of the variances. This would compute the test statistic which would be asymptotically chi-squared with degrees of freedom m-1, where m is the number of endogenous variables.
@PANELFM(SMPL=%PERIOD(T)<=split,other options)
# list of endogenous variables
compute xx1=%xx,beta1=%beta
@PANELFM(SMPL=%PERIOD(T)>split,other options)
compute xx2=%xx,beta2=%beta
compute wald=%qforminv(xx1+xx2,beta1-beta2)
Re: FMOLS Wald Test
Posted: Sat Aug 17, 2013 10:57 am
by atarca
How can I compute this Wald Test statistic for each of the panels by using the %%ibetas and %%ixx? I also need to compare the individual betas of the two samples for each of the cross-section unit. I would be grateful if you could help.
Best Regards,
Atarca
Re: FMOLS Wald Test
Posted: Sat Aug 17, 2013 1:55 pm
atarca wrote:Hi Tom,
Best Regards,
Atarca
That's included in the Pedroni JAE 2007 replication
