Page 1 of 2
Bjornland-Leitemo JME 2009
Posted: Wed Jun 29, 2011 1:28 pm
bjornland_leitemo_jme_2009.zip is a replication for for Bjørnland, Hilde C. and Kai Leitemo (2009): "Identifying the Interdependence between US Monetary Policy and the Stock Market", Journal of Monetary Economics, vol 56, pp 275-282. This uses the @ShortAndLong procedure to estimate a structural VAR on a five variable system, and includes Monte Carlo integration of the IRF's.
If you are looking for a more basic example of short- and long-restrictions with error band calculations, see https://estima.com/forum/viewtopic.php?f=8&t=2335.
Detailed Description
Re: Bjornland-Leitemo JME 2009
Posted: Sat Jul 25, 2015 1:56 am
by shengyang
I revised the program by expanding to 7-variable matrix. However, it keeps showing an error "ShortAndLong failed to converge to a solution". I greatly appreciate if you could give me some advices.
Posted: Sat Jul 25, 2015 7:40 am
What are your SR and LR matrices?
Posted: Sat Jul 25, 2015 9:27 am
by shengyang
SR and LR matrices are as follows; if the LR restriction is removed, the error message will change to "## MAT5. Needed Matrix with Dimensions 7 x 1, Got 5 x 1 Instead"
input lr
. . 0 . . . .
input sr
. 0 0 0 0 0 0
. . 0 0 0 0 0
. . . 0 0 0 0
. . . . 0 0 0
. . . . . . 0
. . . . . . 0
Posted: Sat Jul 25, 2015 10:41 am
How are you distinguishing your 5 and 6 shocks? You're also failing the Rubio-Ramirez-Wagonner-Zha counting rule.
Re: SVAR Montesvar command
Posted: Thu Dec 03, 2015 7:56 am
cczzwhy wrote:Thank you very much! I also get a question on the dataset in Bjørnland, Hilde C. and Kai Leitemo (2009): "Identifying the Interdependence between US Monetary Policy and the Stock Market" paper.Can you tell me how you calculate the monthly data of pi from cpi?
Questions about data should generally be addressed to the authors. However, it's fairly clear that it's 100.0*(log(cpi)-log(cpi{12}))
Posted: Sat Dec 05, 2015 5:56 am
by cczzwhy
Hello,Tom!I got a question about graphing error bands in irf. I am trying to generate a irf with two different error bands like
@MCGraphIRF(model=varmodel,shocklabels=shocklabels,varlabels=varlabels,$
 center=input,impulses=baseirfs,percent=||.025,.16,.84,.975||,$
 footer="Figure 7. Pointwise 68% and 95% Posterior Bands, B-Q Model")
,but my model is a svar,so should I use the code
@MCProcessIRF(model=varvix,percentiles=||.025,.16,.84,.975||,center=median,lower=lower,upper=upper,irf=irf)
What should I do to take the two different pairs of lower and upper vectors out?
Posted: Sat Dec 05, 2015 7:52 am
You would have to do two separate @MCPROCESSIRF's to get two sets of lower and upper (use different names). However, why can't you use @MCGRAPHIRF?
Posted: Tue Dec 08, 2015 4:33 am
by cczzwhy
Thanks for your reply.It is because i am trying to generate a graph like Figure 7-26 in[Introduction to rats*],by using
graph(row=1,col=1,header=varlabels(5),nodates,ovcount=3,overlay=fan,ovsame) 3
,what should I do to generate the fan area if using mcgraphirf?
Posted: Tue Dec 08, 2015 8:07 am
@MCProcessIRF(model=varvix,percentiles=||.025,.975||,center=median,lower=lower95,upper=upper95,irf=irf)
@MCProcessIRF(model=varvix,percentiles=||.16,.84||,center=median,lower=lower68,upper=upper68,irf=irf)
for i = target and j = shock the graph would be something like
graph(overlay=fan,other options) 5
# irf(i,j)
# lower95(i,j)
# lower68(i,j)
# upper68(i,j)
# upper95(i,j)
Posted: Fri Jan 22, 2016 6:26 am
by zoe_z
I have a quick question. If I want to use MC simulation to generate 68% probability bands for impulse responses using Cholesky factorization, can I simply use the same model as for SR-LR but only use SR block, while not restricting LR block?
dec rect lr(5,5) sr(5,5)
input lr
input sr
. 0 0 0 0
. . 0 0 0
. . . 0 0
. . . . 0
This would be a quick way of switching between Cholesky and SR-LR models while getting consistent probability bands for IRFs.
Thanks!
Posted: Fri Jan 22, 2016 9:29 am
Yes. That would work.
Posted: Wed Mar 23, 2016 4:21 am
by cczzwhy
Hello Tom!I have no idea about how to generate the variance composition in this procedure ,is there any examples?
Posted: Wed Mar 23, 2016 8:06 am
The variance decomposition is included in the original program. Look for "errors(". It has to use the factor matrix before standardizing the shocks.
Posted: Sun Mar 11, 2018 10:07 pm
by istiak
There are some numbers in the 5 variable model code that I do not understand. For example, in one line I see that
"@varirf(model=varstockp,steps=nsteps,factor=f,page=byshock,$
shocks=shocklabels,varlabels=varlabels,accumulate=||2,3,4||)"
In another line, I see that
"option vect[int] accum ||1||"
"@SRLRDoDraws(accum=||2,3,4||,steps=nsteps,model=varstockp,lr=lr,sr=sr)"
My question is what do the numbers in ||....||indicate?
If I use a 6 variable or 4 variable or 3 variable model, how do the numbers in the above ||....|| will change?
Thank you so much.
