Marginal Likelihood of BVAR
Posted: Tue Jun 07, 2011 4:44 am
by jonasdovern
Hallo,
a follow up on my previous post (thanks for the answer to that): I am struggling with the computation of the marginal likelihood of my BVAR (that I need to compare different specifications of the BVAR). In the course manual for the course on Bayesian Econometrics there is one example how to compute that for a univariate linear model (Example 3.2). My problems with transferring this example to the multivariate case start already with the calculation of the multivariate gamma-distribution term. How can that be done in RATS?
So, if I have OLS estimates for my VAR obtained by
* Estimate VAR by OLS
system(model=olsmodel)
	variables varlist
	lags 1 to l
	kfset xxx
	det detlist
estimate(noprint) start end
and extract all relevant information for the next steps and compute the prior and its precision by
dim olssee(nvar)
ewise olssee(i) = sqrt(%sigma(i,i))
comp sigma = %sigma
comp xx = inv(xxx)
comp bhat = %vec(%modelgetcoeffs(olsmodel))
*** Create the prior mean and (square root of) precision
if %defined(mvector) {
	comp lmvector = mvector
else {
	dim lmvector(nvar)
	ewise lmvector(i) = 1.
dim minnmean(l*nvar+%rows(detlist),nvar) minnprec(l*nvar+%rows(detlist),nvar) bmean(nvar*(l*nvar+%rows(detlist))) bdiff(nvar*(l*nvar+%rows(detlist))) ux(nvar*(l*nvar+%rows(detlist)))
do i=1,nvar
	do j=1,nvar
		do k=1,l
			comp minnmean((j-1)*l+k,i)= %if(i==j.and.k==1,lmvector(j),0)
			comp minnprec((j-1)*l+k,i)= olssee(j)/olssee(i)*%if(i==j,1.0/tight,1.0/(other*tight))
		end do k
	do j=1,%rows(detlist)
	        comp minnmean(l*nvar+j,i)=0.0,minnprec(l*nvar+j,i)=0.0
ewise minnprec(i,j)=minnprec(i,j)^2
comp hprior = %diag(%vec(minnprec)); * Put everything in vec form
comp bprior = %vec(minnmean)
what would be the next step in calculating the marginal likelihood for that BVAR?
