Page 3 of 6
Re: Gray JFE 1996 Markov Switching GARCH model
Posted: Mon Jan 30, 2017 11:30 am
by jack
You are right. But I want to see if introduction of futures contract has brought about a high wolatility regime? I want to see if this event has increased the volatility. The methodology is based on this paper.
http://onlinelibrary.wiley.com/doi/10.1 ... 3/abstract.The authors have implemented this method.
Posted: Tue Jan 31, 2017 10:03 am
The paper you cited would be more convincing if they did an apples vs apples comparison. The dummy variable model only changes the variance constant in the GARCH while the MS-GARCH model changes everything (mean model, all variance model parameters and the degrees of freedom of the t). Even with all the extra parameters, the improvement in the LL for Nikkei, FTSE and S&P aren't all that large.
Posted: Tue Jan 31, 2017 10:24 am
by jack
I really appreciate your excellent comments on the paper.
Is it possible to have a code for their model here?
And one more question. How can I compute LB statistic for squared residuals of Regime-switching GARCH in Gray's paper?
Posted: Wed Feb 01, 2017 1:17 pm
by jack
I want to compute Ljung-Box statistic for serial correlation of the squared residuals of Regime-switching GARCH model in Gray's paper.
I used the following code after maximize instruction but I'm not sure whether it is correct or not:
set ustd = %dot(pt_t1,||(rate-a01-a11*rate{1})/b01,(rate-a02-a12*rate{1})/b02||)
I would be grateful if you could possibly guide me about it.
Posted: Wed Feb 01, 2017 3:43 pm
by jack
I estimated a model based on Gray's paper and here is the results. The Ljung-Box statistics relating
to the squared standardized residuals indicate significant serial correlation. Does it show that something is wrong with the model?
Convergence in 23 Iterations. Final criterion was 0.0000041 <= 0.0000100
Dependent Variable RATE
Daily(5) Data From 2003:01:03 To 2012:12:06
Usable Observations 2590
Log Likelihood -1106.0489
1. Constant -0.009116152 0.004583112 -1.98907 0.04669295
2. RATE{1} 0.035172878 0.022646726 1.55311 0.12039663
3. C 0.001088115 0.000282215 3.85562 0.00011543
4. A 0.246598747 0.026254036 9.39279 0.00000000
5. B 0.791129966 0.018299852 43.23150 0.00000000
Lag Corr Partial LB Q Q Signif
1 0.053 0.053 7.155283 0.0075
2 -0.008 -0.011 7.314639 0.0258
3 -0.024 -0.023 8.800338 0.0321
4 0.032 0.035 11.463173 0.0218
5 -0.005 -0.009 11.533096 0.0418
6 -0.030 -0.030 13.918315 0.0306
7 -0.030 -0.025 16.257684 0.0229
8 -0.024 -0.023 17.751739 0.0232
9 -0.031 -0.030 20.225390 0.0166
10 -0.016 -0.012 20.850930 0.0222
11 -0.026 -0.025 22.658262 0.0197
12 -0.019 -0.018 23.600898 0.0230
13 -0.027 -0.026 25.444931 0.0202
14 -0.039 -0.040 29.388071 0.0093
15 -0.037 -0.036 32.917932 0.0048
MAXIMIZE - Estimation by BFGS
Convergence in 2 Iterations. Final criterion was 0.0000050 <= 0.0000100
Function Value -1054.0329
1. A01 0.013549085 0.012540572 1.08042 0.27995519
2. A02 -0.014930348 0.004370346 -3.41629 0.00063482
3. A11 0.064567104 0.029604611 2.18098 0.02918480
4. A12 -0.064066500 0.034049382 -1.88158 0.05989361
5. B01 0.067479479 0.005412803 12.46664 0.00000000
6. B11 0.135819468 0.013344841 10.17768 0.00000000
7. B21 0.808728790 0.017795344 45.44609 0.00000000
8. B02 0.003753066 0.000429312 8.74204 0.00000000
9. B12 0.312228200 0.047843182 6.52608 0.00000000
10. B22 0.294668993 0.019177199 15.36559 0.00000000
Convergence in 22 Iterations. Final criterion was 0.0000006 <= 0.0000100
Function Value -1049.7041
1. A01 0.010332656 0.012722085 0.81218 0.41668686
2. A02 -0.015752333 0.004410645 -3.57144 0.00035503
3. A11 0.066010875 0.030439228 2.16861 0.03011215
4. A12 -0.086271210 0.037563514 -2.29668 0.02163728
5. B01 0.050481058 0.009854571 5.12260 0.00000030
6. B11 0.156253488 0.032079328 4.87085 0.00000111
7. B21 0.805724006 0.051333920 15.69574 0.00000000
8. B02 0.003278824 0.001207730 2.71487 0.00663027
9. B12 0.229633335 0.069779573 3.29084 0.00099889
10. B22 0.249913547 0.039345596 6.35175 0.00000000
11. P(1,1) 0.959801475 0.014292487 67.15427 0.00000000
12. P(1,2) 0.076891035 0.021664827 3.54912 0.00038652
1 0.0339 0.0339 2.988551 0.0839
2 0.0330 0.0319 5.815595 0.0546
3 0.0209 0.0188 6.950812 0.0735
4 0.0580 0.0558 15.691318 0.0035
5 0.0679 0.0634 27.684503 0.0000
6 0.0430 0.0356 32.499693 0.0000
7 0.0521 0.0445 39.564417 0.0000
8 0.0292 0.0194 41.786765 0.0000
9 0.0177 0.0056 42.605573 0.0000
10 0.0320 0.0206 45.269952 0.0000
11 0.0659 0.0541 56.593080 0.0000
12 0.0233 0.0090 58.003813 0.0000
13 0.0301 0.0184 60.358844 0.0000
14 0.0519 0.0414 67.379388 0.0000
15 0.0336 0.0184 70.331039 0.0000
I used the following code for computing the LB statistics for Regime-switching GARCH model:
Posted: Thu Feb 02, 2017 12:18 pm
by jack
I want to compute Ljung-Box statistic for serial correlation of the squared residuals of Regime-switching GARCH model in Gray's paper. I used the following code (after maximize instruction) for this purpose but the results are very different from those in the paper:
set ustd2 = %dot(pt_t1,||(rate-a01-a11*rate{1})/b01,(rate-a02-a12*rate{1})/b02||)
set usqr2 = ustd^2
@regcorrs(report,number=15) usqr2
Posted: Thu Feb 02, 2017 2:51 pm
The first three are actually fine---it's after that that the test seems to have problems. First of all, the LB test is based upon assumptions that might not hold (and probably don't) in this situation---you might get a different result with the more robust West-Cho test. Also, it's not clear what the effect is on the multi-step diagnostics of the way the "memory" is cut off by the filtering process.
Posted: Thu Feb 02, 2017 3:16 pm
by jack
1. When I want to reproduce LB for the squared residuals of Regime-switching GARCH model in Gray's paper (by the following code), the results are very different from those in the paper. what's wrong with it?
set usqr2 = ustd^2
2. Can I make statistical inference based on the LB that shows significant correlations after the third lag?
3. Is there any remedy for my model?
I would be really grateful if I can possibly have your insightful comments.
Posted: Thu Feb 02, 2017 9:24 pm
Gray never really defines what he means, but it looks like this works (in the sense that it appears to very closely match his results):
set usqr gstart gend = uu(t)/h(t)
@regcorrs(title="Squared Standardized Residuals from MS GARCH",$
number=15,report) usqr
This can be applied to all of the MS GARCH models. (What you were computing is definitely not correct, since you're only taking the variance constant part of the GARCH recursion).
Posted: Fri Feb 03, 2017 9:23 am
by jack
I run the code after the maximize instruction but I got the following error:
SX11. Identifier GSTART is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>set usqr gstart <<<<
Posted: Fri Feb 03, 2017 9:33 am
Use 2 * instead of gstart gend.
Posted: Fri Feb 03, 2017 3:38 pm
by jack
I'm really confused.
I'm using Gray's paper for modeling my daily exchange rate returns. There are strange results. When I estimate a simple GARCH model, the coefficient of AR(1) term in mean equation is statistically
insignificant and positive. But the Ljung-Box statistics relating to the standardized residuals indicate
But when I estimate a Regime-switching GARCH model, the coefficients of AR(1) terms in mean equations are
statistically significant and negative (and positive). And the Ljung-Box statistics relating to the standardized residuals indicate
no serial correlation.
I'm really confused. I don't know how to interpret these results. Is it possible to have such results? Is something wrong with the model?
1 0.101 0.101 26.498775 0.0000
2 0.030 0.020 28.797444 0.0000
3 0.041 0.036 33.131069 0.0000
4 0.036 0.028 36.542802 0.0000
5 0.035 0.027 39.646718 0.0000
6 0.003 -0.006 39.664611 0.0000
7 0.042 0.039 44.273612 0.0000
8 -0.012 -0.023 44.649073 0.0000
9 -0.009 -0.009 44.864559 0.0000
10 0.043 0.042 49.584950 0.0000
11 -0.027 -0.036 51.470142 0.0000
12 0.005 0.009 51.537103 0.0000
13 -0.037 -0.038 55.046241 0.0000
14 0.011 0.016 55.336143 0.0000
15 0.023 0.023 56.758591 0.0000
Regime-switching GARCH:
1 0.027 0.027 1.934771 0.1642
2 -0.018 -0.019 2.791808 0.2476
3 -0.042 -0.041 7.414761 0.0598
4 -0.029 -0.027 9.548227 0.0488
5 -0.009 -0.009 9.753434 0.0825
6 -0.020 -0.022 10.767742 0.0958
7 -0.021 -0.022 11.861776 0.1052
8 0.002 0.001 11.877841 0.1567
9 0.014 0.010 12.358070 0.1939
10 0.042 0.038 16.870462 0.0773
11 0.011 0.008 17.207434 0.1019
12 0.003 0.004 17.225406 0.1413
13 0.025 0.028 18.802433 0.1294
14 0.009 0.011 19.022561 0.1641
15 0.007 0.010 19.152047 0.2069
Posted: Sun Feb 05, 2017 5:08 pm
I don't find that at all odd. None of those coefficients are particularly large.
Posted: Fri Jun 16, 2017 3:36 am
by jack
When I run the model I get this error:
NO CONVERGENCE IN 4 ITERATIONS
LAST CRITERION WAS 0.0000000
Is there any way for handling this error?
Posted: Fri Jun 16, 2017 9:06 am
What model with what instructions? That usually means either really really bad guess values or so many preliminary iterations that the model is effectively converged and BFGS can't figure out the curvature.
