Page 2 of 3
Re: BAIPERRON—Multiple change point analysis
Posted: Tue Dec 01, 2015 4:45 pm
Correct.
Posted: Sun May 08, 2016 9:14 pm
by elhampa
Hello Tom,
I am not very clear what is the difference between @BaiPerron and @multiplebreaks codes.
Would you please advise about it?
Regards
Elham
Posted: Sun May 08, 2016 9:47 pm
elhampa wrote:Hello Tom,
Regards
Elham
@BaiPerron is for a model with breaks in time (entry). @MultipleBreaks is for models which break based upon some other variable (which wouldn't even have to be in the model)---for instance, the type of breaks that you see in threshold models.
Re: BAIPERRON procedure for multiple change points
Posted: Sun Dec 11, 2016 9:54 am
by jonasdovern
TomDoan wrote:pls wrote:Hi Tom:
I also conducted the regression using the Bai-Perron procedure and found that there are breaks.
However, I would like to correct for heteroscedasticity and autocorrelation.
Perhaps I could make a change to the procedure in the linreg statement and add "robust" as an option.
The Bai-Perron algorithm picks the break based upon homoscedastic errors, but allows for some HAC errors in doing some other calculations. However, if you want to choose breaks allowing for HAC errors, you can use the calculations from the ONEBREAK.RPF example file.
Has anybody done that already and can post a modified BAIPERRON.SRC?
That would be of great help!
Posted: Sun Dec 11, 2016 2:29 pm
Sorry, but what does "that" refer to? (The quote includes two separate ways to handle heteroscedasticity).
Posted: Mon Dec 12, 2016 2:59 am
by jonasdovern
Oh, I meant using the approach from ONEBREAK.RPF to adapt the BAIPERRON procedure to fully base the test on HAC standard errors. (What I am actually interested in is to obtain test statistics which are robust to autocorrelation; heteroskedasticity is no issue in my application.)
Posted: Mon Dec 12, 2016 11:44 am
The contribution of Bai-Perron is that it shows how to efficiently locate
multiple breaks in a regression. At one break, it's effectively the same calculation as in (say) @APBreakTest. To achieve the efficiency, it relies upon an assumption of homoscedastic errors, which is why the HAC is included in the analysis only after the breaks have been chosen. To allow for HAC errors (and there's no simple way to separate the H and the AC in that) throughout with multiple breaks, you have to go back to the basics of running a whole lot of regressions as is done in the ONEBREAK example for a single break. The general structure for doing multiple breaks is in the
User's Guide, Section 11.3.
Posted: Tue Dec 13, 2016 2:12 am
by jonasdovern
Ok. Thanks for clarifying this, Tom.
What I still do not completely understand is at which point/for which calculations the BAIPERRON procedure does take HAC errors into account (as you mentioned in one of the previous posts). It seems not to be able to activate the robust option in the BPBreakRanges procedure.
But lets say I change this: is it right that then the only thing that would take deviations from iid errors into account would be the calculation of the widths of the error bands for the break date?
Posted: Tue Dec 13, 2016 9:29 am
That's correct. Just for the break point CI's.
bai perrron breaks
Posted: Wed Jun 28, 2017 10:09 am
by pls
The Bai-Perron procedure prints out the breaks as follows:
Breakpoint Lower 95% Upper 95%
664 569 666
853 852 887
1226 1222 1227
1278 1276 1281
I am not using "Calendar" and the dates corresponding to the break are in another variable "week" which is in the main program.
How can I pass out the breaks--664, 853, 1226, 1278 to the main program so that I can print out the week corresponding to the break?
I think the change has to be made to the bai-perron procedure at the following part
@BPBreakRanges(robust,qhet,omegahet,maxbreaks=maxbreaks,nfix=nfix,nshift=nshift,breaks=breaks) startr endr eqnswitch limits
* Display the break points with 95% confidence bands
report(use=regreport,atrow=baserow,atcol=1) "Breakpoint" "Lower 95%" "Upper 95%"
do k=1,maxbreaks
report(use=regreport,atrow=baserow+k,atcol=1) %datelabel(breaks(k)) %datelabel(limits(k,1)) %datelabel(limits(k,2))
end do k
I have tried the following in the procedure:
compute brk1 = %datelabel(breaks(1))
and a display in the main program as
display brk1
but I get an error message.
Posted: Thu Mar 29, 2018 4:17 pm
The newest versions of @BAIPERRON define %%BREAKPOINTS which is a VECT[INT] with the chosen breaks.
Posted: Wed Jul 25, 2018 1:01 am
by elhampa
Hello Tom,
The series I am working with are not cointegrated. I have use the ARDL test (Pesaran, MH, Shin, Y & Smith, RJ 2001, 'Bounds Testing Approaches to the Analysis of Level Relationships', Journal of Applied Econometrics, vol. 16, no. 3, pp. 289-326).
As fa as I understand this test is for cointegrated models. In such case there is no point to use Kejriwal and Perron test for multiple structural. However after running the multiple structural break one break was detected and the coefficients are statistically significant over the two regimes.
Would you please advise and correct me if I am wrong.
Thank you very much.
Regards
Posted: Wed Jul 25, 2018 5:12 pm
Regards
If your series are
not cointegrated, then a y on x regression is spurious. If you're doing an ARDL type model (with multiple lags of of x variables), then the model should be written in differences, and then you don't have any issues with I(1) regressors. The problem then is that you may not produce an easily interpretable equation. See
https://estima.com/ratshelp/spuriousregression.html
Posted: Thu Jul 26, 2018 8:30 pm
by elhampa
Thank you very much Tom,
I think the way I mentioned my questions was a bit vague. What I am asking is:
All I want to show is that y and x are not cointegrated (I am no looking for modelling y and x).
y and x were tested for cointegration using the ARDL model (with multiple lags of of y and x) proposed by (Pesaran, MH, Shin, Y & Smith, RJ 2001, 'Bounds Testing Approaches to the Analysis of Level Relationships', Journal of Applied Econometrics, vol. 16, no. 3, pp. 289-326).
The ARDL test revealed that Y and x are not cointegrated.
Now, considering the ARDL result, is there any point of using Kejriwal and Perron test(esting for Multiple Structural Changes in Cointegrated Regression Models." Journal of Business and Economic) to test whether y and x are cointegrated?
In other way, is Kehriwal and Perron test only for when x and y if they are cointegrated?
Thank you Tom
Posted: Thu Jul 26, 2018 8:46 pm
Kejriwal and Perron is not a test for cointegration. It's a test for structural breaks in an equation with cointegration.
