Page 2 of 2
Re: VAR-GARCH BEKK and irf
Posted: Fri Oct 23, 2009 9:14 am
by moderator
I think the SHOCKS option is documented fairly clearly in the "FORECAST" section of the Reference Manual.
Briefly, you can either define the vector of shocks ahead of time, or provide the vector using the literal matrix notation. For example, if you had a 3 equation model, the option would be something like
shocks=||s1, s2, s3||
replacing s1, s2, and s3 with the desired shock for each equation.
Posted: Sat Dec 12, 2009 4:33 am
by nikosant
I think what luxu1983 wishes to get is based on the following paper: Hafner & Herwartz 2006 - Volatility impulse responses for multivariate GARCH models: An exchange rate illustration.
Posted: Tue Dec 15, 2009 8:01 am
by luxu1983
moderator wrote:I think the SHOCKS option is documented fairly clearly in the "FORECAST" section of the Reference Manual.
dear
if i use a MAXIMIZE mgarch variation (bekk)
how can i get the irf
Posted: Tue Dec 15, 2009 12:57 pm
luxu1983 wrote:dear
I would suggest defining the VAR using SYSTEM, then put the estimated VAR coefficients into it using the %modelsetcoeffs. You just need to make sure you get the coefficient matrix set up in the right form. Once you've done that, you can just use IMPULSE the way you would if you were estimating the model using the GARCH instruction.
Posted: Tue Jan 04, 2011 3:36 pm
by vinayadhikari
I think the above gives the impulse responses of the mean equation. Can anyone share the code of impulse responses in variances as in
& Herwartz 2006? Thank you.
Posted: Tue May 15, 2012 10:50 am
