Page 2 of 2
Re: Transition or migration matrices in RatS
Posted: Mon Aug 24, 2009 9:13 am
by Aqu_nb
sorry the matrix looks like:
0.39581 0.07705 0.01245 0.00205 0.00085 0.00013 0.01165
0.04980 0.32419 0.09470 0.01749 0.00290 0.00045 0.01046
0.00463 0.05876 0.32108 0.08518 0.01558 0.00227 0.01250
0.00092 0.01041 0.09079 0.28290 0.08201 0.01024 0.02273
0.00034 0.00204 0.02927 0.14299 0.22622 0.05427 0.04488
0.00002 0.00017 0.00232 0.02726 0.08753 0.29964 0.08306
and the rows and colums does not add to 1 or 100 %?
Posted: Mon Aug 24, 2009 9:27 am
The rows are adding to 1/2 rather than 1 which is very puzzling. It looks like you need to send the program and data file to support@estima.com so we can try to run it and see what's going on. That should work.
Posted: Mon Aug 24, 2009 10:01 am
by Aqu_nb
Aqu_nb wrote:
TomDoan wrote:display transit
will do that.
Yes it works. But the problem now is that the rows or colums does not sum 1 (100%). The ouput looks like following:
1 2 3 4 5 6 Default
1 0.39581 0.07705 0.01245 0.00205 0.00085 0.00013 0.01165
2 0.04980 0.32419 0.09470 0.01749 0.00290 0.00045 0.01046
3 0.00463 0.05876 0.32108 0.08518 0.01558 0.00227 0.01250
4 0.00092 0.01041 0.09079 0.28290 0.08201 0.01024 0.02273
5 0.00034 0.00204 0.02927 0.14299 0.22622 0.05427 0.04488
6 0.00002 0.00017 0.00232 0.02726 0.08753 0.29964 0.08306
What do you think the problem can be?
Thanx again:-)
Sorry the matrix looks like:
Posted: Mon Aug 24, 2009 10:04 am
by Aqu_nb
TomDoan wrote:The rows are adding to 1/2 rather than 1 which is very puzzling. It looks like you need to send the program and data file to support@estima.com so we can try to run it and see what's going on. That should work.
Sorry I did not saw your mail it was on page 2. I will send the program and the data to support@estima.com .
Posted: Mon Aug 24, 2009 11:12 am
by Aqu_nb
Ok now I have send a mail with the data (attached) and the program to support@estima.com.
Posted: Mon Aug 24, 2009 5:53 pm
by Aqu_nb
I actually think that I have the transition matrices correct. Now I need to calculate whether the estimated probabilities of recession and expantion matrices are significantly different from the unconditional matrix. In oeder to do so I will need some standard errors. How do I calculate the standard errors.
Regards
Atef
Posted: Tue Aug 25, 2009 4:49 pm
Aqu_nb wrote:Dear Tom,
Regards
Atef
There's a separate nclass x nclass covariance matrix for the elements of each row. The row estimates are independent of each other.
dec vect[symm] rowcv(nclass)
do c=1,nclass
   dim rowcv(c)(nclass,nclass)
   ewise rowcv(c)(i,j)=(transit(c,i)*(i==j)-transit(c,i)*transit(c,j))*rowscales(c)
end do c
The covariance matrix of the difference between two (independent) estimates of a row in the transition matrix is the sum of corresponding covariance matrices, that is, if you compute a rowcv1 and rowcv2, the covariance matrix for the difference between row i in the two estimates will be rowcv1(i)+rowcv2(i). Note that this is a singular matrix since the probabilities have to sum to 1. The %qforminv function can compute a chi-squared test statistic that allow for the singular covariance matrix. For instance, if you have two estimates of the transition matrix, the test for whether the 1st rows are the same can be done with:
compute test1=%qforminv(rowcv1(1)+rowcv2(1),%xrow(transit2,1)-%xrow(transit1,1))
cdf chisqr test1 nclass-1
The degrees of freedom is nclass-1 rather than nclass because of the singularity.
