Page 2 of 2
Re: VAR AGARCH model (optimal weight, hedge ratio and Hedgi
Posted: Sat Jun 27, 2020 7:23 am
by curiousresearcher
Thanks for the guidance here.
Posted: Wed Feb 24, 2021 1:43 am
by ndanila
I want to estimate the hedge ratios and portfolio weights between three variables: conventional stock, shariah stock and currency.
Following your earlier post (the hedges ratios), I am successful with setting the hedge ratios. However, I still have problems as below:
1. put the hedge ratios in table (pull out the hedge ratios)
2. write command for portfolio weights
3. put the weights in table (pull out the weights)
Your guidance is highly appreciated
Thank you
Nevi
