structural models for time series
Re: structural models for time series
For quarterly, this would be something like:
compute s=4
all 200
dec vect[series] zt(s-1)
dec frml[vect] cf
do h=1,s/2
   set zt(2*h-1) = cos(2*%pi*h*t/s)
   if 2*h<=s-1
      set zt(2*h) = sin(2*%pi*h*t/s)
end do h
frml cf = %xt(zt,t)
dec symm sigmaeta(s-1,s-1)
compute sigmaeta=%diag(||.1,.1,.3||)
compute sigmaeps=||1.0||
dlm(type=simulate,c=cf,sw=sigmaeta,sv=sigmaeps,yhat=ysim,presample=ergodic) 1 200
set y = ysim(t)(1)
mcorozcos
Unread post by mcorozcos »
Hello Tom,
Thanks for your help.
But now I need to change a serie of Random Walk that I attachment the code, in one serie that include elements seasonal, like this equation
yt = summation of h=1 until h=[s/2] of γt(h),
Where,
yt is a random walk, like that, γt(h) = γt−1(h) + ηt(h), h= 1, ..., [s/2],
nt is a white noise, like that, ηt(h) ∼ IID (0, Σ η(h)), h= 1, ..., [s/2],
I don´t understand how I include h= 1, ..., [s/2], in the random walk and the white noise in order to create the serie simulated
Again, I need a simulate serie of 500 observations, the same that I created
thanks for your help
Regards
compute n = 500
compute rvar=1.0
set a 1 n = 0.0
set u 1 n = 0.0
do i=1,n
compute a(i)=%ran(rvar)
compute p = 1
do i=1,p
compute u(i)=%ran(rvar)
do i=p+2,n
compute u(i)=u(i-1)+a(i)
The program I wrote does that. The "sum" is done by the C vector. Work through the state-space representation, and you'll see.
mcorozcos
Hello Tom,
I tried to write the program but I have problems:
1. I have a problem when I tried to make a white noise with the rank h=1......[s/2], because it show only fourth observations, the others are zero.
2. When, I created a vector c, it have an error " ## DLM5. Probable Model Error. Diffuse prior was not reduced to zero rank" and I tried to make differents things in order to find a solution for this error, but I do not know what happened.
Can you help? I attachment my code in order to revise which is the problem.
compute n = 500
compute rvar=1.0
set a 1 n = 0.0
set u 1 n = 0.0
compute s = 4
do h=1, s/2
compute a(h)=%ran(rvar)
end do h
print / a
compute p = 1
do h=1,p
compute u(h)=%ran(rvar)
end do h
*do i=p+2,n
*compute u(i)=u(i-1)+a(i)
*end do i
*print / u
all 500
dec vect[series] vt(s-1)
dec frml[vect] cf
do h=1,s/2
   set vt(h) = u(h-1)*t+a(h)*t
end do h
frml cf = %xt(vt,t)
dlm(type=simulate,c=cf,sw=sigmaeta,sv=sigmaeps,yhat=ysim,presample=ergodic) 1 500
set y = ysim(t)(1)
Regards
What I wrote does your model. I converted it into state space form from the somewhat odd notation used by the authors. The DLM does the simulations---all you have to do is change the variances.
mcorozcos
thanks, but if I created a randown walk with variance 1.0 for one distribution normal, what kind of variance I have to put in the instruction dlm?
The variances are controlled by:
sigmaeta are the variances of the random walks on the Fourier series. It sounds like you want those all to be 1.0. sigmaeps is the purely random error---you'll have to figure out what you want there.
mcorozcos
Hello Tom,
I have a question: I tried to change of code, data monthly and I have many problems with dimension of matrix cf because it is diferent. How I use this instrucction for data monthly?
I have an other question: which is the best form to extract of seasonal for two simulated series? I tried to use X11 but this instruction can´t use for negative data, only data positive, acording with error of RATS
Finally, I need to fit a model, for two series of data reals (monthly or quarterly), the model is:
yt = μt+st + εt,
μt = random walk
st = component seasonal, like the code of down
εt ∼ IID (0, Σ ε) white noise
yt = are series of data reals, monthly or quarterly
I hope you can help me, again thank you so much
TomDoan wrote:For quarterly, this would be something like:
compute s=4
all 200
dec frml[vect] cf
do h=1,s/2
   if 2*h<=s-1
end do h
frml cf = %xt(zt,t)
set y = ysim(t)(1)
Change S=4 to S=12. There are now 11 component variances in sigmaeta.
You can use X11 with an additive adjustment (not multiplicative or log additive). However, isn't this supposed to be a state-space model of seasonality?
mcorozcos
Hello Tom
Thanks for your explication about the change a data monthly, I have a question, the values of matriz of variances sigmaeta, can be numbers anyone?
Yes, it is a model space state of seasonality, but I need to apply a other metodology, for this reason I need to extract the seasonality.
What about the fit of the model before?
mcorozcos wrote:Hello Tom
Perhaps you should contact the authors of the paper to find out what kinds of values they think are reasonable. They could be any non-zero values, but what's reasonable (in comparison to the pure-noise variance) is not clear. If they are too high, the seasonals will be too variable to be useful.
mcorozcos
Hello Tom,
Can you help me with a example: how do I use the instruction @LocalDLM(options) and @SeasonalDLM(options)? because I need to fit the next model:
yt = μt+st + εt,
μt = random walk
st = summation of h=1 until h=[s/2] of zt(h)*γt(h)
Where,
Zt(h) = (IN ⊗ zt(h)') , zt(h) = (cos λ(h)t, sin λ(h)t)0 for h < s/2 and, when s is even, zt(s/2) = cos λ(s/2)t = cos πt.
I think that with it instruction, is posible fit the model a set of data. Because I revised the components of instruction its has the elements the model that I write above. But I don´t understand how do I use those instruction in a model fit, with the instruction dlm.
Regards
Your model has a non-standard treatment of seasonality. I have no idea what reasonable values are. What did the authors of the article tell you? It's their model.
mcorozcos
Hello Tom,
Yes, I understand that the seasonal component its different for this reason, I need to help. But, you doesn´t matter. Don´t worry. Thanks
Now, you can help with any example about how used the instruction: @localdlm and @seasonaldlm, in the instruction dlm, for two series, the idea is to estimate the parametres of trend component, seasonal component and irregular component,(yt =ut + st + et), and I need the residuals or errors of model. I need to extract each comun components for the two series.
I read the manual for those instructions, but only have example, for one series, I can see that in this example is posible to do things that I need to do for two series.
Regards
There are quite a few examples of @seasonaldlm in various textbook examples. See the list at
http://www.estima.com/cgi-bin/bookbrows ... xtbook=Any
