Long term covariance for Multivariate GARCH
mengqi
Is there any code for calculating long term covariance matrix for multivariate GARCH-BEKK model?
Many thanks.
Many thanks.
mengqi
Re: Long term covariance for Multivariate GARCH
Am I correct that for BEKK, the long run covariance matrix is equal to [(I-AA'-BB')^(-1)]*CC'
I have a bivariate-GARCH(1,1)-BEKK model, How do i generate this "I" - identity covariance matrix?
Can I use SUMMARIZE command to evaluate the long run covariance matrix?
It's easiest to do that by transforming to a VECH representation. After estimating the BEKK model:mengqi wrote:Hi,
Many thanks.
@mvgarchtovech(mv=bekk) * * Check the roots of the VECH recursion * eigen(cvalues=cv) %%vech_a+%%vech_b disp %cabs(cv(1)) * * If the dominant root is larger than one, the following calculation is invalid * compute vechhinf=inv(%identity(%nvar*(%nvar+1)/2)-%%vech_a-%%vech_b)*%%vech_c compute hinf=%vectosymm(vechhinf,%nvar)
No. You need Kroneker products for the A and B. That's why it makes more sense to convert to the VECH representation which takes care of doing the Kroneker product and reducing the calculation to the VECH of the symmetric matrix.mengqi wrote:Am I correct that for BEKK, the long run covariance matrix is equal to [(I-AA'-BB')^(-1)]*CC'
mengqi
Thanks for your reply.
I used the code but have the following results. How do i define vech_a?
## SX11. Identifier %%VECH_A is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>lues=cv) %%vech_a+%<<<<
Common errors are
* a missing $ at the end of a long line which continues to the next
Many thanks.
Common errors are
Many thanks.
You didn't do the @MVGARCHToVECH.
mengqi
Thanks. It worked. But the result is 1.10285 larger than one. So I cannot use the rest of the code?
Does it mean i cannot obtain long run covaraince?
Correct. There is no stationary solution.
mengqi
Can I use the above code to evaluate the long run covariance for DCC model instead of BEKK?
Regards
Regards
There is no long-run covariance for a DCC. The whole point is for the covariances to change from period to period.
