ARCHTEST—Test for ARCH/GARCH effects
@ARCHTEST does the Engle test for ARCH effects by regressing the square of a series on its lags and testing the significance of the lags. The null is that the series is mean zero, not serially correlated and has constant variance. This can be used to test the original series for ARCH (or GARCH) by applying it to residuals from a preliminary LINREG (to satisfy the requirement that the series be mean zero and not serially correlated). It can also be used as a diagnostic by applying it to the standardized residuals from GARCH estimation. Note that you apply the procedure to the residuals, not to their squares. (The procedure handles the squaring).
A multivariate version is available with @MVARCHTEST.
Detailed description
upani
Arch test
Hi All,
I want to do ARCH test to a univariate time series to decide whether Garch (1,1) model can be applied to the data set or not. I have used the following command:
I got the following output.
I want to know the interpretation for the above result. I am confused as for some lag it is significant and some lag it is not significant. Would you please clarify the doubt. I have gone through the GARCH course material which i have purchased from Estima. I did not get any answer to my problem.
With sincere regards,
Upananda
open data 'ndata2.xlsx'
calendar(a) 1987
data(format=xlsx,org=columns) 1987 2013 Price
set ret = 100*log(Price/Price{1})
linreg(noprint) ret / resids
# constant
set res = resids
source archtest.src
@archtest(lags=12,span=1) res
Test for ARCH in RES
Using data from 1988:01 to 2013:01
Lags Statistic Signif. Level
1 2.063 0.16439
2 0.975 0.39372
3 0.545 0.65725
4 0.356 0.83619
5 7.292 0.00120
6 7.387 0.00133
7 5.909 0.00486
8 4.599 0.01754
9 4.019 0.04008
10 2.821 0.13193
11 1.722 0.36025
12 0.845 0.70191With sincere regards,
Upananda
Re: ARCHTEST - Test for ARCH/GARCH effects
Is this actually annual data? Annual data rarely has GARCH properties. Given that there is nothing in the short lags, there is no reason to believe that a GARCH model will work. That looks a lot like very noisy data with at least a few large outliers separated by five observations.
Max Resende
Re: ARCHTEST—Test for ARCH/GARCH effects
Dear RATS users,
I want to do an @ARCHTEST to a univariate time series as a preliminary test to decide whether a Garch model can be applied to the data set or not. I have used the following command:
I got these results:
I would like to know if my interpretation is correct:
Since the Lagrange multiplier test coefficients are significant, that means that I might have a GARCH Process (residuals are not constant).
Best regards,
Max
* ARCH Test
linreg r / resids
# constant
@archtest(lags=6,form=lm,span=1) residsCode: Select all
Test for ARCH in RESIDS
Using data from 2010:01:05 to 2018:12:28
1 65.096 0.00000
2 114.418 0.00000
3 134.175 0.00000
4 139.460 0.00000
5 147.649 0.00000
6 150.318 0.00000
Best regards,
Max
Yes. (Residuals are not constant variance),
