Balcilar, Gupta and Miller, EE 2015
Re: Balcilar, Gupta and Miller, EE 2015
If you want to use ||8.0,2.0|| rather than ||19.0,1.0||, go ahead. They're priors. 8,2 isn't as persistent and is weaker, but both of those will be dominated by 1800+ data points. If you have 100 data points, then those are going to be much more strongly informative.
atarca
Unread post by atarca »
In one of the rows of "oil_stock_msvecm_irf.rpf", "set dloil = %if(dloil==0.0,%ran(.1),dloil)" is used to "Fuzz" up the zero values of dloil. What is the meaning of (.1) used in %ran(.1)?
Thank you very much in advance.
Standard deviation of the normals. The specifics for functions are included in the help.
atarca
Thank you very much for your quick reply, Tom. However, I wonder why it is %ran(.1) instead of being %ran(1.0) in this case.
Because it's supposed to be small random numbers to prevent the exact fit problem.
alexecon
Unread post by alexecon »
TomDoan wrote:
The expected "labeling" of regimes is that regime 1 will be the low volatility and regime 2 the high volatility. This pushes the guess values in that direction, and then runs the EM algorithm for 100 iterations, followed by 10 iterations of BHHH to allow calculation of standard errors for the estimates:
@MSSysRegInitial gstart gend
* Try to enforce regime 1 as having lower volatility
compute sigmav(1)=.25*sigmav(1)
compute sigmav(2)=4.0*sigmav(2)
@MSSysRegEMGeneralSetup
do emits=1,100
   @MSSysRegEMStep gstart gend
   disp "Iteration" emits "Log likelihood" %logl
end do emits
set p1smooth = psmooth(t)(1)
* Polish estimates with 10 iterations of BHHH. Set up the parameter sets
* and initialize the regime probability matrices (required for ML, but
* not EM, which uses its own).
nonlin(parmset=regparms) betasys sigmav
nonlin(parmset=msparms)  p
compute p=%xsubmat(p,1,nstates-1,1,nstates)
frml logl = f=%MSSysRegFVec(t),fpt=%MSProb(t,f),log(fpt)
@MSFilterInit
maximize(start=$
  %(logdet=%MSSysRegInitVariances(),pstar=%MSSysRegInit()),$
  parmset=regparms+msparms,method=bhhh,iters=10) logl gstart gend
Why is the EM 'pre-estimation' necessary in the MS-VECM of Balcilar et al. (2015) and not in the MS-VAR of Ehrmann et al. (2003)? Thank you.
I don't think "necessary" is the right word. The EEV replication includes both a direct BFGS estimation and another program which does EM followed by BHHH. These are two approaches to doing maximum likelihood with models like this.
abi
Unread post by abi »
Since MS-VECM use the @johmle procedure if there are some breaks in the data set, then the result of MS-VECM still would be valid?
Yes. The ML estimates of the cointegrating vector are consistent under a very wide range of assumptions.
LvXin
Unread post by LvXin »
I would like to use this code to estimate MSVECM mode with 1 and 3 lags (in VECM). Whether this code could achieve this, and how could I modify the code to estimate 1 and 3 lags model. Thanks very much for your kind help.
Lags 1 and 3 on the differences? Not sure that that's a good idea, but
# dlsp{1 3} dloil{1 3} constant ect{1}
would do that in this example.
LvXin
Thanks very for your quick reply. Mayebe I could not explain clearly last time. I would like to estimate two MS-VECM model
Model 1: MS(2)-VECM(1): Yt=μ(st )+Π(i(st)) ΔY(t-1)+Γ(i(st)) Y(t-1)+εt, st=2 states, Yt represents a vector sf observed time series variable
Model 2: MS(2)-VECM(3): Yt=μ(st )+Π(i(st)) ΔY(t-3)+Γ(i(st)) Y(t-3)+εt, st=2 states, Yt represents a vector sf observed time series variable
So, How could I modify the code?
# dlsp{1} dloil{1} constant ect{1}
and
# dlsp{3} dloil{3} constant ect{3}
LvXin
Thanks very much!
I successful estimate the code: # dlsp{1} dloil{1} constant ect{1}. However, when I estimate below code: # dlsp{2} dloil{2} constant ect{2} and # dlsp{3} dloil{3} constant ect{3}, the RATS report as:
## NL6. NONLIN Parameter SIGMAV(1)(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(1)(2,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(1)(2,2) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(2)(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(2)(2,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(2)(2,2) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter P(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter P(1,2) Has Not Been Initialized. Trying 0
What's the problem? Do I need to modify some other code? In addition, which variable is the regime duration in the results. Thank again for your kind help!
I'm really confused about what you're trying to do. Why are you skipping lags in a VECM? If you're simply trying to change the number of lags, you just need to fix the first and last lines in the code below. (4 and 3 will have 3 lags on the differences in the VECM, 3 and 2 would have 2). If you do a full set of differences (and it's not clear why you wouldn't, particularly before estimating the model), then the lag of the EC term doesn't matter.
The program is designed to run all the way through given a choice of model. If you try to change the model up and re-do part of the analysis, it won't work.
@johmle(lags=2,det=constant,cv=cv)
# loil lsp
* Normalize to a unit coefficient on oil
compute cv=cv/cv(1)
* This is the error correction series
set ect = cv(1)*loil+cv(2)*lsp
equation(coeffs=cv) ecteq *
# loil lsp
* LAGS=2 is chosen for the full VAR, so that involves 1 on the differences.
compute lag=1
