a question on seasonally adjusted
Postby hardmann » Tue May 14, 2013 10:09 am
Dear Tom:
When I learn ecourse state space,I have a deep question. In BN or UC decomposion, series have been seasonally adjusted before, and in commandeur & koopman's book, or stock & watson's dynamic factor model, they all estimate season component. Can we decompose directly a series into level, trend, seasonal, irregular and cycle with AR(2)? Addtional, for a same series and start point, if end points are different, seasonally adjusted series are also different under same method.
Best Regard
hardmann
hardmann
Re: a question on seasonally adjusted
Postby TomDoan » Tue May 14, 2013 11:12 am
hardmann wrote:Dear Tom:
You could, but unless there's something else involved in the model, the combination of the AR(2) and the local level/trend is usually too much flexibility.
hardmann wrote:Addtional, for a same series and start point, if end points are different, seasonally adjusted series are also different under same method.
That's true with any smoothing procedure.
Return to State Space Models/DSGE
