Hello
i am working on a garch model with detailed instructions, all goes well but when i execute the last maximasation procedure, it can't find the data points.
## SR10. Missing Values And/Or SMPL Options Leave No Usable Data Points.
TomDoan wrote:Have you read page UG-294 in the version 8 User's Guide?
TomDoan wrote:Is there a reason you're not using the GARCH instruction?
The problem is that you're using a bad set of guess values. Your off-diagonal GARCH terms are more persistent than your diagonal GARCH terms---as a result, you're producing a non-positive definite covariance matrix on the very first entry.
TomDoan wrote:You still are using very bad guess values. You have .05 coefficients on the own lagged variance terms and .50 on the lagged squared residuals. In a typical GARCH, the lagged variance term is the dominant one. Plus, the guess values on the off-diagonals give an unstable recursion.
Have you looked at the behavior of univariate GARCH models on these series first? Given that what you're doing nests uni GARCH models, starting with guess values based upon the univariates would be a good idea.
Users browsing this forum: Google [Bot] and 2 guests
