Dueker JBES 1997 MS-GARCH models
Postby TomDoan » Mon Sep 12, 2011 1:30 pm
These are replication files for Dueker(1997), "Markov Switching in GARCH Processes and Mean-Reverting Stock-Market Volatility," J of Business & Economic Statistics, vol. 15, no 1, 26-34 using a reconstruction of the original data file. Dueker fits several different models with different types of switching. All of models allow the mean to switch, but two of these have "variances" switching, and two have the degrees of freedom in the conditional t density switching in different ways.
Switching GARCH (as opposed to ARCH) models require "collapsing" the history of the regimes in some fashion. Dueker waits one period longer for this than Gray(1996) does in "Modeling the conditional distribution of interest rates as a regime-switching process", J. of Financial Economics, vol 42, pp 27-62. This actually makes it easier to adapt the technique to different models than Gray's.
Switching GARCH models is one of the topics in the course materials: viewtopic.php?f=24&t=1185
dueker_swgarch.rpf
GARCH model with switching mean (only)
(4.66 KiB) Downloaded 196 times
dueker_swgarch_nf.rpf
GARCH model with switching variance
(5.53 KiB) Downloaded 217 times
dueker_swgarch_df.rpf
GARCH model with switching degrees of freedom in t error process
(5.26 KiB) Downloaded 149 times
dueker_swgarch_k.rpf
(5.29 KiB) Downloaded 155 times
dueker_swarch.rpf
SWARCH model
(4.65 KiB) Downloaded 179 times
sp500.xls
(Reconstructed) data file
(93 KiB) Downloaded 201 times
Re: Dueker JBES 1997 MS-GARCH models
Postby lumengobobo46 » Tue Apr 16, 2013 3:01 am
I am trying to display the conditional variance according to the different regimes for the first programme (DUEKER-SWARCH). I use the followings:
set momo = gv(1)*h(i)
graph
# momo
i have an answer: missing operator or adjacent operator.
please can you help. I will also like to display the series momo.
Regards
lumengobobo46
Postby TomDoan » Tue Apr 16, 2013 10:12 am
1. Where are you putting this?
2. The "ARCH" factors are dependent upon the expanded states (8 of them with two regimes and two lags + current) and the GV scaling depends upon the contemporaneous regimes, so you wouldn't be using gv(1). Are you looking for eight time series, or did you want something else?
Postby lumengobobo46 » Tue Apr 16, 2013 3:45 pm
Hi tom
Thank you for your prompt response
1. I write the code at the end of the programme.
2. I want to obtain all the time series for conditional volatility (ARCH) related to the different regimes. they are more than 2000 observations.
Regards
lumengobobo46
Postby TomDoan » Tue Apr 16, 2013 3:51 pm
lumengobobo46 wrote:Hi tom
Regards
What I'm saying is that at each point in time, there are eight numbers, one for each combination of regimes for t, t-1 and t-2. At any given time period, many of those will have virtually zero probability, so the conditional volatility could be almost complete nonsense. I don't think those time series are especially useful---so the question is, what do you really want?
Postby lumengobobo46 » Wed Apr 17, 2013 2:31 am
Hi Tom
I am currently trying to replicate a paper: "Rodrigues, J.C. (2007). Measuring financial contagion: A copula approach, journal of emepirical economics,14, 401-423." by using my own data. The main idea of the paper is to find dependence of conditional volatilities in high and low regime (states) of volatilities. i thought that if i can have time-series data of volatilities in the different regimes, after estimating a SWARCH model, then i could model a copula to find dependence between them. I am expecting the dependence to be different in the different regimes(represented by those time series i would like to derive from the estimated SWARCH model).
REgards
lumengobobo46
Users browsing this forum: Google [Bot] and 1 guest
