maximum likelihood estimators
Postby Nabtheberliner » Fri Apr 05, 2013 12:56 pm
Hello everyone,
i'm new with RATS software, i used to work with SAS. So my questions are simple:
How do we program RATS to get the ML estimators when we study a VAR(p) process?
With the OLS estimators, there is no problem.
My second question is : How do we write or obtain the Mean adjusted form of a VAR process?
I didn't find any answers in the RATS user's guide, none in the examples and programs provided by Estima.
Thanks a lot for your help
Nabtheberliner
Re: maximum likelihood estimators
Postby TomDoan » Tue Apr 09, 2013 12:52 pm
Nabtheberliner wrote:Hello everyone,
If you're talking about full-information maximum likelihood for a VAR, that can be done using a state-space representation with DLM. That's rarely done in econometrics since it precludes unit roots.
Nabtheberliner wrote:My second question is : How do we write or obtain the Mean adjusted form of a VAR process?
That's also rarely done except as a step in a more involved model, for exactly the same reason that ML isn't used much.
What is it that you're trying to do?
Postby Nabtheberliner » Tue Apr 09, 2013 2:05 pm
Actually i'm studying the Helmut Lûtkepohl's book "New introduction to multiple time series analysis", so i'm finishing the fifth chapter, and try to do the exercices.
I'm dealing with a bivariate VAR(1).
He asks to compute the OLS/YULE-WALKER and ML Estimators
Concerning the 2 first estimators i have no problem.
I have a problem to compute the forecast MSE Matrix aswell.
SO if you have any idea, please let me know.
Thanks a lot
Nabtheberliner
Postby TomDoan » Tue Apr 09, 2013 4:05 pm
Nabtheberliner wrote:Actually i'm studying the Helmut Lûtkepohl's book "New introduction to multiple time series analysis", so i'm finishing the fifth chapter, and try to do the exercices.
The mean-adjusted VAR (as defined in the book) simply means the VAR on the data with the sample means subtracted.
Which exercise are you looking at that is asking about the ML estimator for a VAR(1)?
Nabtheberliner wrote:I have a problem to compute the forecast MSE Matrix aswell.
Thanks a lot
Have you looked at the worked examples for the book?
Postby Nabtheberliner » Thu Apr 11, 2013 1:27 pm
i send you here the programs for the exercices.There is a attached file called E2 from Lütkepohl.
You are right i wasn't precise enough, the matter is how do i get in the Problem 3.13 the estimation of the covariance matrix of the asymptotic distribution of the ML estimators.
Also what do mean by "worked examples for the book",do you mean the textbook programs provided by estima?
By the way do you have the book " New Intro To Multiple..." ?
Tahnks a lot for your help
PROGRAM
OPEN DATA "C:\Users\nabihamaraoui\Desktop\NEW INTRODUCTION TO MULTIPLE TIME SERIES ANALYSIS\E2.txt"
CALENDAR(Q) 1949:1
DATA(FORMAT=PRN,ORG=COLUMNS) 1949:01 1974:04 y1 y2
*PROBLEM 3.11:Plot thwo times series y1t and y2t and comment on the stationarity and stability of the series
spgraph(header=' series y1t and y2t',vfields=2,hfields=1,footer='figure 1') 2
graph(header='series y1t',vlabel='Y1',hlabel='dates',footer='panel:1',key=upleft) 1
# y1
graph(header='series y2t',vlabel='y2',hlabel='dates',footer='panel:2',key=upleft) 1
# y2
*PROBLEM 3.12: Estimate the parameters of a VAR(1) model for(y1t,y2t)' using multivaiate
*LS,that is compute B^(coefficient matrix) and SIGMA^u(residual cov matrix).
*comment the stability of the estimated process
system(model=US)
variables y1 y2
lags 1
estimate(sigma,outsigma=V) * 1968:4
* This will give the roots of the companion matrix, which will be the
* reciprocals of the roots of the polynomial in the text. Thus, the
* stability condition is for the largest (first in the order produced by
* EIGEN) to be less than one.
compute companion=%modelcompanion(US)
eigen(cvalues=cv) companion
disp cv(1) "with absolute value" %cabs(cv(1))
* We can notice that the coefficients are not good,in the first regression
*with y1 as dependent variable, the coef of y1(1)=1.013
* and we check with roots of the companion matrix which are greater than 1
* so the estimated VAr(1) process is not stable
*PROBLEM 3.13: Use the adjusted-mean form of the VAR(1) model and estimate the
*the coefficients .Assume that the data generation process is Gaussian and
*estimatthe covariance matrix of the asymptotic distribution of the ML estimators
* first i get the sample mean
table
*i substract the sample mean from the data
set y1t = y1 - 110.8990
set y2t = y2 - 6.0980
E2.txt
(1.84 KiB) Downloaded 8 times
Nabtheberliner
Postby TomDoan » Thu Apr 11, 2013 1:51 pm
Nabtheberliner wrote:Dear Tom,
See
http://www.estima.com/cgi-bin/bookbrowser_singlebook.cgi?Textbook=lutkepohl
They are also on the software distribution.
Postby TomDoan » Thu Apr 11, 2013 1:55 pm
Nabtheberliner wrote:PROGRAM
CALENDAR(Q) 1949:1
# y1
# y2
system(model=US)
variables y1 y2
lags 1
table
The first suggestion is never to do a de-meaning calculation like that. Do
diff(center) y1 / y1t
diff(center) y2 / y2t
You don't lose precision that way.
The calculation required is
system(model=USDEMEAN)
variables y1t y2t
lags 1
estimate(sigma,outsigma=VDEMEAN) * 1968:4
You run the VAR by least squares on the mean-adjusted data without a CONSTANT in the regression. The full covariance matrix would be
disp %kroneker(%sigma,%xx)
Postby Nabtheberliner » Thu Apr 11, 2013 5:27 pm
Thanks a lot Tom, i check this out
Nabtheberliner
Postby Nabtheberliner » Fri Apr 12, 2013 3:02 pm
Hello Tom,
Thanks it workx perfectly!
A quick question 'cause i'm jumping from SAS to RATS, it's not easy, so my question is:
the options outsigma is supposed to provide the covariance matrix of the residuals, why in the output it is named Covariance\Correlation Matrix of Coefficient?it's a bit confusing,unless i missunderstood if so sorry for that.
Best regards
Nabtheberliner
Postby TomDoan » Fri Apr 12, 2013 3:14 pm
Nabtheberliner wrote:Hello Tom,
Best regards
The structure of the output is described on page Int–76 of the version 8 Introduction to RATS. The OUTSIGMA option (or %SIGMA variable) are the covariance matrices themselves and they are symmetric. For the output, rather than duplicate the numbers above the diagonal, it converts those to correlations which you may also find interesting. In fact, while the covariance matrix is what generally gets used in further calculations, it's the correlations (the above the diagonal) that actually provide more useful information for a quick check of what is happening.
Postby Nabtheberliner » Sat Apr 13, 2013 2:55 pm
Thanks Tom,
Now i'm very clear about what is inside the output.
Yet, it remains a little confusion.
Indeed, in the RATS Handbook, W.Enders discribes the outsigma as the covariance matrix of the residuals, so my confusion is coefficients and residuals, more precisely
do i have to consider that covariance matrix of the residuals and the covariance matrix of the coefficients are the same? which looks strange for me.
Sorry if it has to be obvious.
Thanks Tom
Nabtheberliner
Postby TomDoan » Sun Apr 14, 2013 8:33 am
Nabtheberliner wrote:Thanks Tom,
Thanks Tom
No, they're different. They just use the same method of display (the covariance\correlation matrix). RATS doesn't have an option to produce a covariance matrix of coefficients for a VAR as that would ordinarily be too large a matrix to be viewable. You can do
display %kroneker(%sigma,%xx)
or
compute covmat=%krokener(%sigma,%xx)
medit covmat
Postby Nabtheberliner » Sat Apr 20, 2013 2:36 pm
Thanks a lot for your help.
I looked at it and applied it to the Chapter 2 to be clear, the example that Luetkepohl gives with the file E1:west german economy and the 3 variables invest/income/conumption.
So if i understood before going any further with my questions, i wrote the program
OPEN DATA "C:\Users\naceur\Desktop\econometrics time series\NEW INTRO TO MULTIPLE TIME SERIES ANALYSIS\etude1 West german economy Lütkepôhl\westgermaneco.txt"
CALENDAR(Q) 1960:1
DATA(FORMAT=PRN,ORG=COLUMNS) 1960:01 1982:04 invest income cons
set ldinvest = log(invest / invest{1})
set ldincome = log(income / income{1})
set ldcons = log(cons / cons{1})
system(model=L)
variables ldinvest ldincome ldcons
lags 1 to 2
estimate(sigma,outsigma=V) * 1978:4
display %outsigma=V
OUTPUT which is the same in the book "New Intro To Multiple...." p.80 , which is t[u]he estimate of the residual covariance matrix
Covariance\Correlation Matrix of Coefficients[/u]
LDINVEST LDINCOME LDCONS
LDINVEST 0.0019254179 0.13242415 0.28275482
LDINCOME 0.0000647493 0.0001241684 0.55526108
LDCONS 0.0001114228 0.0000555654 0.0000806498
I rescale it to get the same exactly in the book:
display "Rescaled Covariance Matrix" 1.0e+4*%sigma*%nobs/(%nobs-%nreg)
Estimate of the residual covariance matrix
21.29629
0.71617 1.37338
1.23240 0.61459 0.89204
OUTPUT which is covariance matrices for the coefficients
0.01423 0.00347 0.00238 0.00208 -0.02033 -0.01675 3.33643e-004 4.78539e-004 1.16571e-004 8.01993e-005 6.99329e-005 -6.83716e-004 -5.63211e-004 1.12200e-005 8.23486e-004 2.00600e-004 1.38010e-004 1.20343e-004
-0.00118 -9.69192e-004 1.93077e-005
0.00347 0.01411 -0.00882 -6.00646e-005 0.00161 -0.01793 2.00045e-004 1.16571e-004 4.74354e-004 -2.96758e-004 -2.01989e-006 ........................................................................................etcera
If cross the informations from Lütkepohl,Enders and you,
Is that correctly understood?
Thanks Tom for your patience, i hope it is clear for you
westgermaneco.txt
(2.45 KiB) Downloaded 6 times
Nabtheberliner
Postby TomDoan » Mon Apr 22, 2013 9:48 am
Yes, that would be how you get the grand covariance matrix of the coefficients. As you can see, it isn't very practical to display it---even for a rather small VAR like this, it's a 21 x 21 matrix, and he doesn't even try to show it in the book. Instead, he displays the t-statistics, which use only the diagonals. And if you check them out, you'll see that they're exactly what's already shown in the output, just in a slightly different order; RATS puts the constant last, while he puts them first.
Postby Nabtheberliner » Tue Apr 23, 2013 9:24 am
Thanks a lot, it's clear.
May i come back to the PB3.13 from Lütkepohl:
*estimate covariance matrix of the asymptotic distribution of the ML estimators
I'm fine with the demean problem,this is clear, but
this code is about the estimate covariance matrix of the asymptotic distribution of the ML estimators ?
What i understand is that this cov matrix is ralated to the demean form of the VAR but still with the ols estimates,and as you said "You run the VAR by least squares on the mean-adjusted data without a CONSTANT in the regression". So OLS and ML Estimators are asymptoticaly identicals based on the subsection of the Lütkepohl 's book p.90 subsection 3.4.3 Properties of the ML Estimators
Is it correct?
Thanks for the clarification Tom
Nabtheberliner
Next
Return to Other Time Series Analysis
