MVARCHTEST - multivariate test for GARCH effects
Postby TomDoan » Mon Jan 17, 2011 5:03 pm
Attached is a procedure for testing a set of series for multivariate ARCH effects. The null is that the series are mean zero, not serially correlated and with a fixed covariance matrix. It performs an LM by regressing the crossproducts of the series (that is u(i,t) x u(j,t) for all combinations of i and j) on a constant and its lag(s) and testing the coefficients on the lags. The number of degrees of freedom is
(n(n+1)/2)^2 x the number of lags
since it is including all crossproducts on all crossproducts.
mvarchtest.src
(2.68 KiB) Downloaded 226 times
@MVARCHTest( options ) start end
# list of series
(start and end default to the common range of the series)
Options
LAGS=number of ARCH lags to test [1]
[PRINT]/NOPRINT
Variables Defined
%CDSTAT Test statistic
%SIGNIF Significance level of the test
Re: MVARCHTEST - multivariate test for GARCH effects
Postby LeCaptain » Wed Feb 13, 2013 12:11 pm
Is this based on any paper, i.e. are there any references for this? How to cite? For the MVQStat, for instance, you refer to Hosking (1981).
LeCaptain
Postby TomDoan » Tue Mar 12, 2013 12:51 pm
It's a fairly obvious extension of the LM test to multivariate ARCH. Based upon the description, it sounds like
R. Scott Hacker & Abdulnasser Hatemi-J, 2005. "A test for multivariate ARCH effects," Applied Economics Letters, Taylor and Francis Journals, vol. 12(7), 411-417
is the same thing, though that's behind a pay wall, so I can't be sure.
Postby LeCaptain » Thu May 09, 2013 10:22 am
TomDoan wrote:It's a fairly obvious extension of the LM test to multivariate ARCH. Based upon the description, it sounds like
I think the article you cited comes very close. Thank you, Tom!
LeCaptain
Return to RATS Procedures
Who is online
Users browsing this forum: Google [Bot] and 1 guest
cron
