dynamic equicorrelation
Postby Anja » Fri Sep 11, 2009 5:23 pm
Has anyone implemented the DECO model of Engle and Kelly(2012), "Dynamic Equicorrelation", JBES, vol 30, no 2, 212-228.
Thank you
Anja
Re: dynamic equicorrelation
Postby TomDoan » Wed Feb 10, 2010 1:21 pm
This uses one of the standard RATS example data files. (Not a great choice for the technique, since the Canadian exchange rate has a low correlation with the others).
garchdeco.rpf
Program file
(2.54 KiB) Downloaded 52 times
g10xrate.xls
Data file
(1.2 MiB) Downloaded 40 times
Postby xray » Wed Nov 21, 2012 9:24 am
Is it possible to form the minimum variance and global minimum variance portfolios as done in the DECO paper (http://papers.ssrn.com/sol3/papers.cfm? ... id=1354525) using matrix algebra in RATS?
Thanks!
xray
Postby xray » Fri Nov 23, 2012 7:09 am
Hi all,
Does anybody know how to even output the covaraince matrix? I assume its the same as for the DCC model is anyone knows that?
Thanks!
xray
Postby TomDoan » Wed Nov 28, 2012 1:27 pm
xray wrote:Hi all,
Thanks!
The version of this just posted now computes the covariance matrices as the SERIES[SYMMETRIC] called HH.
Postby TomDoan » Wed Nov 28, 2012 1:35 pm
xray wrote:Hi,
Thanks!
Their process would take a lot of programming. Calculating the portfolios is simple given the covariance matrices. However, in order to avoid biasing the results, they run rolling estimates, but in order to avoid the cost of running too many optimization problems, they re-estimate only once in 22 periods, and do a sequence of 22 one-step predictions, using the last set of estimates. They also cut out the description of how to forecast the "rho" out-of-sample from an earlier working paper. It isn't analytical and they gave two different expressions, so it's not clear which they recommend.
Postby xray » Thu Nov 29, 2012 6:31 am
Is it possible to display this in the matrix form
HH =
hh11............hh1,8
hh1,8...........hh8,8
The print and display commands don't seem to work
xray
Postby TomDoan » Thu Nov 29, 2012 10:24 am
There is one HH matrix per time period. You can do
DISPLAY HH(100)
to get the HH matrix at T=100, and the same for any other data point.
